Dual ISP and Path Selection
rrockliff
Hi All
We want to setup Dual ISP Connections, I know there is a lot of info around about this topic using Route Maps and IP SLA, however these seem to be better suited to a failover situation.
The scenario
our customer has a mGRE VPN Setup with one ISP they however want choose what traffic gets routed out of a particular ISP Service.
For example,
we want all Windows Updates and internal traffic over the VPN to go VIA ISP1
we want all general Web Traffic for browsing going out ISP2
We also want to be able to re-route all Traffic, including the internal Traffic over ISP2 (if ISP1 Goes Down) Maybe IP SLA will help here.
Any thoughts or suggestions on how we could acheive this
Thanks in advance
Marwan ALshawi
Yes you got it right you need ipsla
However to get it working in the way you want you need PBR with ipsla for path selection and failover also you need to consider the nat configuration
Please refer to the bellow document I posted before on csc which will help you to achieve what you want
https://supportforums.cisco.com/docs/DOC-8313
If helpful rate
