Dual Links from 4431 to Nexus N9K vPC Domain - Config Help please
Cormac Champion
Hi all,
I'm looking configure a routed connection to connect dual links from a 4431 into a Nexus N9K Domain.
So on the 4431, I have
int g0/0/0 - 1
channel-group 1
int po1
ip address 192.168.0.1/30
However, on the N9K's, I can obviously do pretty much the same thing, but can I put the same IP Address on Po1 on each of the two switches in the vPC Domain ?
So each N9K would have the SAME
int eth1/1
channel-group 1 mode on
int po1
ip address 192.168.0.2/30
Or do I need to do it with Vlans and HSRP ?
Cormac Champion
I sorted it out.  For others, you need to create Vlans with HSRP and assign the Vlan to your Port Channel
Cormac Champion
Question, on the 9K's you said you created a VLAN, assuming 2000, you then created the SVI's with the HSRP configurations and the IP 192.168.0.2 /30 and then added the VLAN to the vPC right? Please explain a bit further as I have a similar set up coming up where I have 2 7000 Nexus running vPC and I was thinking on how to connect my 4451x router to both Nexus.
So on the router, have something like the following
int g0/1
switchport access vlan xx
channel-group 1
int g0/2
channel-group 1
int po1
ip address xx.xx.xx.xx /29
On EACH nexus
int eth1/1
int vlan xx
hsrp xx
preempt
priority 110
ip xx.xx.xx.xx
int po1
vpc x
So you are essentially doing a /30 link from the router to the N7K but you'll need to use a /29 due to the 4 addresses required.
Hope that helps
