Dual sim not working cisco 819G
shenmaia24
Cisco C819G-LTE-LA-K9 (revision 6.0) with 883788K/33715K bytes of memory.
Processor board ID FGL212190NG
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
3 terminal lines
1 Virtual Private Network (VPN) Module
2 Cellular interfaces
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
I have an issue when using dual sim, when switch another ISP on slot 1 sim, it failed to ping  8.8.8.8 and also how to do troubleshoot failover to ensure failover is running?
Below my config
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte sim data-profile 1 attach-profile 1 slot 1
lte failovertimer 5
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
no ip route-cache cef
load-interval 60
dialer in-band
dialer pool-member 2
dialer-group 1
async mode interactive
interface Dialer1
description
no ip redirects
no ip proxy-arp
ip nat outside
dialer pool 2
dialer string lte
dialer watch-group 1
dialer-group 1
no cdp enable
dialer watch-list 1 ip 1.1.1.1 255.255.255.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 10
dialer watch-list 1 delay disconnect 20
dialer-list 1 protocol ip permit
typically you would use an EEM script that clears the ip routing table in case of failover. Try to do it manually ('clear ip route *') once the failover has occurred.
To check which profile is active, use the command:
show cellular 0 profile
If the failover is working, it should show one profile as active, the other as inactive.
That said, post the full configuration of your router...
i using different ISP, Once doing clear ip route still use same ISP. can you advise how to config EEM script since i using ipsec vpn connect to my core router.i need to ensure when isp signal is low it will switch to another isp or when data reach limit it will switch to other ISP,
Below full config on my router.
Current configuration : 8021 bytes
! Last configuration change at 02:02:20 UTC Wed Jan 9 2019 by alif
version 15.6
hostname shen
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ethernet lmi ce
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.128
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
!NG
username alif privilege 15 secret 5 $1$jwex$B1BsDFQ3v5.9YpGpnbESl1
lte failovertimer 5
no cdp run
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key keyless address 202.x.x.x
crypto isakmp nat keepalive 20
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set alif esp-3des esp-md5-hmac
mode tunnel
crypto map myalif 10 ipsec-isakmp
set peer 202..x.x.x
set transform-set alif
match address alif
dlsw local-peer peer-id 30.0.0.110
dlsw remote-peer 0 tcp 30.2.2.251
dlsw remote-peer 0 tcp 30.2.2.250
dlsw remote-peer 0 tcp 10.123.1.2
dlsw remote-peer 0 tcp 30.2.2.253
dlsw remote-peer 0 tcp 20.2.1.138
dlsw remote-peer 0 tcp 30.2.2.254
dlsw remote-peer 0 tcp 20.2.1.147
dlsw remote-peer 0 tcp 20.2.1.145
dlsw remote-peer 0 tcp 30.1.1.2
dlsw remote-peer 0 tcp 30.1.1.3
dlsw remote-peer 0 tcp 10.125.1.2
dlsw bridge-group 1
interface Loopback0
ip address 30.0.0.110 255.255.255.255
interface Cellular0
ip nat outside
encapsulation slip
load-interval 60
dialer in-band
interface Cellular1
no ip address
encapsulation slip
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
description test-ip
duplex auto
speed auto
interface Serial0
description Direct
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clock rate 9600
sdlc role primary
sdlc vmac 2000.0110.1000
sdlc address AB
sdlc xid AB 01403280
sdlc partner 4000.0000.0002 AB
sdlc dlsw AB
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.128
ip tcp adjust-mss 1452
interface Vlan2
description Device LAN
ip address 10.60.107.222 255.255.255.252
interface Dialer1
description << Dialer associated with Cellular Interface >>
no ip redirects
no ip proxy-arp
ip nat outside
dialer pool 2
dialer string lte
dialer-group 1
no cdp enable
crypto map myalif
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended alif
permit ip host 30.0.0.110 any
permit ip 10.60.0.0 0.0.0.255 any
permit ip host 10.17.19.249 any
permit ip 30.0.0.0 0.0.0.255 10.17.19.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
based on your information, I have come up with the configuration below. Important parts are marked in bold:
version 15.6
hostname shen
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
import all
lease 0 2
no ip domain lookup
ip cef
no ipv6 cef
!NG
lte failovertimer 5
no cdp run
controller Cellular 1
lte sim data-profile 2 attach-profile 1 slot 1
lte failovertimer 5
no cdp run
encr 3des
hash md5
group 2
mode tunnel
set peer 202..x.x.x
match address alif
dlsw bridge-group 1
interface Loopback0
interface Cellular0
ip nat outside
encapsulation slip
load-interval 60
dialer in-band
dialer pool-member 1
routing dynamic
interface Cellular1
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
routing dynamic
no ip address
no ip address
no ip address
no ip address
description test-ip
duplex auto
speed auto
interface Serial0
description Direct
no ip address
encapsulation sdlc
no keepalive
nrzi-encoding
clock rate 9600
sdlc role primary
sdlc address AB
sdlc dlsw AB
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
interface Dialer1
description << Dialer associated with Cellular Interface 0 >>
no ip redirects
no ip proxy-arp
ip nat outside
dialer pool 2
dialer string lte
dialer-group 1
no cdp enable
crypto map myalif
interface Dialer2
description << Dialer associated with Cellular Interface 1>>
no ip redirects
no ip proxy-arp
ip nat outside
dialer pool 2
dialer string lte
dialer-group 1
no cdp enable
crypto map myalif
ip http server
ip local policy-route-map TRACK_PRIMARY
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer2 254
ip nat inside source route-map NAT_TO_DIALER_1 interface Dialer1 overload
ip nat inside source route-map NAT_TO_DIALER_2 interface Dialer2 overload
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer1
timeout 1000
frequency 2
ip sla schedule 1 life forever start-time now
access-list 101 permit icmp any host 8.8.8.8
access-list 102 deny ip host 30.0.0.110 any
access-list 102 deny ip 10.60.0.0 0.0.0.255 any
access-list 102 deny ip host 10.17.19.249 any
access-list 102 deny ip 30.0.0.0 0.0.0.255 10.17.19.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.127 any
access-list 102 permit 10.60.107.220 0.0.0.3 any
route-map TRACK_PRIMARY permit 10
match ip address 101
set interface Dialer1
route-map NAT_TO_DIALER_1 permit 10
match ip address 102
match interface Dialer1
route-map NAT_TO_DIALER_2 permit 10
match interface Dialer2
event manager applet CLEAR_NAT
event track 1 state any
action 1.0 cli command “enable”
action 2.0 cli command “clear ip nat translation *”
action 3.0 cli command "clear ip route *"
control-plane
line 3
exec-timeout 0 0
script dialer lte
login
modem InOut
Hi Sir
Many thanks for kind assistance
As now running config follow as per advise,im not sure event manager is working as i try to clear ip route still use same ISP.  i also having problem failed to ping my hub router(192.168.x.x) from laptop ip address (10.60.107.221). ipsec tunnel is up can ping hub router inside branch router(cisco819)
Below error command
shen(config)#controller cellular 1
% Invalid input detected at '^' marker.
shen(config)#controller cellular ?
<0-0> Controller unit number
current setting
lte sim data-profile 2 attach-profile 2 slot 1
lte failovertimer 5
shen(config)#ip sla 1
shen(config-ip-sla)#icmp-echo 8.8.8.8 source-interface Dialer1
shen(config-ip-sla-echo)#timeout 1000
%Error: timeout is less than threshold 5000
shen(config-ip-sla-echo)#frequency 2000
current config
ip sla 1
shen(config-ip-sla-echo)#timeout 5000
frequency 2000
Current config
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation translation"
From Laptop ip 10.60.107.221
Tracing route to 192.168.14.X over a maximum of 30 hops
1 1 ms <1 ms <1 ms 10.60.107.222
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
