Dual stack on tunnel interface
The.Sorrow
Is it possible to run dual stack IP schemes over an ipsec-protected tunnel interface on IOS? I am able to assign the IPv6 addresses like a normal interface on both ends however when i try to ping across the tunnel with IPv6 there is no response. Here is an example of my config:
R1
interface Tunnel0
 description Tunnel to R2
 ip address 172.30.1.237 255.255.255.252
 ip mtu 1400
 ip nat inside
 ip virtual-reassembly
 load-interval 30
 ipv6 address FE80::172:30:1:1 link-local
 ipv6 address 2001:1::172:30:1:1/126
 keepalive 5 4
 tunnel source GigabitEthernet0/1
 tunnel mode ipsec ipv4
 tunnel destination 1.2.3.4
 tunnel protection ipsec profile protect-gre
R2
interface Tunnel0
 description Tunnel to R1
 ip address 172.30.1.238 255.255.255.252
 ip mtu 1400
 ip nat inside
 load-interval 30
 ipv6 address 2001:1::172:30:1:2/126
 ipv6 address FE80::172:30:1:2 link-local
 keepalive 5 4
 tunnel source FastEthernet0/1
 tunnel destination 1.2.3.5
The only solution i can clearly see is running a separate tunnel, which i would like to avoid. Any assistance is greatly appreciated!
6 Replies 6
I have similar problem as well. It seems it is not supported on IOS version 15.x and below. Unless on newer IOS (XE) 16.x.
Can anyone correct me ?
a.alekseev
Level 7
Level 7
try to use gre
It may works but I still the IPSEC though ...
gre + tunnel protection
It works. I can ping from both side of the tunnel. But IPv6 OSPF doesn't work through this tunnel even I configured the IPv6 OSPF network point-to-point statement under the tunnel. Any idea to make it work?
show the configurations
