Dynamic load-balancing based on link load
paa
Hi!
I have a 2821 connected to two ISP with BGP. How can I configure dynamic load-balancing between two ISP (outgoing traffic) based on outgoing links loads?
Giuseppe Larosa
Hello  Paa,
you cannot do this with BGP only.
you would need optimized edge routing / Performance routing
see
http://www.cisco.com/en/US/docs/ios/oer/configuration/guide/12_4t/oer_12_4t_book.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello  Paa,
see
Hope to help
Giuseppe
Actually you can load-balance with BGP using the "BGP dmzlink-bw" feature.
although it doesn load-balance based on load, but based on bandwidth of the links to your SP.
HTH,
Nhat
Hello Nhat,
original poster had asked for a way to load balance outbound based on link load
I agree that BGP dmzlink-bw" feature may be of help in dealing with links of different speeds
Hope to help
Giuseppe
