Dynamic Routing Configuration
okanyilmaz
We have cisco 2821 routers connected to WAN with 2 ways.
With e1 (say E1 0/0) and Frame-relay (serial 2/0).
And also i have a main device connected through E1, say, Controller E1 0/1.
I need such a routing configuration that would tell my main device (E1 0/1) that primary link is down (E1 0/0).
Any help would be much appreciated.
Thanks.
Okan
spremkumar
Level 9
Level 9
Hi Okan
you can try configuring object tracking feature in your box which can help you out to track the link status of the link connected on the ethernet port of your router.
you can refer the below link in configuring up the same..
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbeb.html
regds
