Dynamically iOS vulnerability scan
PLC
Hi there,
I was recently tasked to keep an eye out on our ios versions and coodinate upgrades for those that have vulnerabilities. Is there a enterprise software that can run a scan on ios  across the network for ios vulnerabilities?
I have solarwinds and created a dashboard with all network equipment ios and will be manually checking bugs on cisco bug checker.
5 Replies 5
BradEast1
Level 3
Level 3
Thanks Brad, I actually tried this now and so far I see some expired warranties and EOL but havent found anything so far for iOS version and vulnerbilities which is a good thing.  If there was a vulnerabilitie or known bug with ios version will the advisor tell you?
Yes. It would show when you go to "View Devices" and also send you a weekly summary via email.
Julio E. Moisa
Please check these links:
 Also you will find more tools here
https://www.cisco.com/c/en/us/support/web/tools-catalog.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Have you used smart advisor? and is there a security concern in doing so?
