E1 configuration issue
Kevin Hart
I have an international circuit with the following configuration. Is this correct? Will G.704 at one end and G703 -> X.21 work ok.
A end - 3640 with a E1 G.703 card running in framed mode (G.704, 1984k) connecting onto G.703 International CCT.
B end - International CCT.
G.703 > x.21 conversion
Cisco 3640 with x.21 interface, terminating the cct.
Circuit runs clean, until cct is loaded. We then see high number of input errors / CRC.
Not 100% sure about above configuration. Any help would be appreciated
.Kevin
dsouzavincent
Hi Keven,
Could you explain your problem a bit more detailed.
1. Is the ckt up ?
2. Where are the errors seen ?
3. Wht is the error rate / per minute ?
4. Cud u paste the config ?
Answers to your questions.
1. Yes, the circuit is up.
2. Input errors on cisco router at the A end, which increase with load.
3. unknow at this point. We don't manage the router. we just provide the circuit.
4.
A end Config
controller E1 0/1
framing NO-CRC4
channel-group 0 timeslots 1-31
interface Serial0/1:0
ip address < removed>
ip pim sparse-dense-mode
carrier-delay 15
no fair-queue
serial restart-delay 90
nrzi-encoding
hold-queue 950 in
hold-queue 950 out
B end config
interface Serial0/1
bandwidth 1984
no fair-queue
serial restart-delay 0
hold-queue 950 in
hold-queue 950 out
5mlarsson
You can not run framed E1 in one end and unframed E1 in the other. Router A expects a sync channel where router B sends data so you will probably see an E1 out of sync error in router A. Incoming data to router B is corrupted by the sync channel so you will probably see CRC errors on a link protocol level.
Try to see if the G.703<->X.21 converter can be set to framed G.704 mode.
Thanks for your response.
The G.703 -> x.21 converter has now been set to unframed E1 (g.703) and the remote end router configured for unframed E1. Circuit is currently running clean.
I think the problem was related to the remote end modem, which is only capable of running in unframed E1 mode.
Initially the circuit was configured as the following
remote end
router (framed E1)
DSU (unframed E1)
int. circuit.
UK end
DSU (framed)
router (X.21)
What I don't understand is why the circuit came up in the first place, due to the remote end mismatch. Remote Carrier unable to provide any support.
Kevin
