06-25-2015 02:11 AM - edited 03-05-2019 01:45 AM
We have a E1 PRI interface suddenly down.
Here are some show commands:
sh int ser0/0/0:15
Serial0/0/0:15 is down, line protocol is down
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 carrier transitions
Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
sh isdn statu
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial0/0/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
sh controllers e1
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Description: ISDN E1 Telecom
Transmitter is sending remote alarm.
Receiver is getting AIS.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (171 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 171 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
Besides, ISDN modem shows DSL and DTE lines as up.
Telco is saying there is an issue on the corporate gateway router. I'm not convinced. I suspect there is a failure on the Telco equipements.
Any idea?
06-26-2015 05:28 AM
If its not circuit it may be local patch cable or port might gone bad. You could replace the local patch cable with a spare and also you can try hard loop the circuit for port related problem.
Kasi
06-29-2015 12:05 AM
A local loop gives me the following output:
E1 0/0/0 is down. (Local Line Loopback) (Line Loop by Remote)
07-01-2015 04:18 AM
It was not a cable issue. The problem was on the Telco side. I told the Telco that I was receiving the AIS alarm and just before I was going to restart the CSU/DSU I saw a change on the LEDs. It seemed that they did something meanwhile.
07-06-2015 12:19 AM
May be Telco has chaged the port..in the log we can able to find Layer1 Deactivated..
So he may suspect due to cable issue.
06-30-2015 03:37 AM
Please check the physical connectivity....
