E1 Software loop
deephazz02
I have a VWIC-2MFT-E1 on a 2800 router.
I have to set up a software loop on the router to check the two E1 links (channelized). Would someone know how to set up a soft loop to test the E1 links.
Regards.
paolo bevilacqua
All the loop command are configured under controller. You can loop the line toward the circuit, the router, etc.
cisco_lad2004
Level 5
Level 5
I vaguley remember the commands, try below:
Controller E1 X/Y
E1 N loopback local
Sam
deephazz02
Conf t > Controller E1 X/Y/Z > loopback local line
