Easy Virtual Network Shared Services - BGP route import
radek_rams
I use this guide to create shared service:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/evn/configuration/xe-3s/evn-xe-3s-book/evn-shared-svcs.html
How in this setup advertise routes from tenants into BGP table of shared vrf?
In shared vrf route appears as connected with + attribute (replicated route).
Under bgp configuration when I tried to use redistribute connected routes from tenants do not import into BGP table.
I need to use route targets if I have BGP routing upstream shared vrf?
Giuseppe Larosa
Hello Radek,
this easy VPN solution document tries to avoid to use BGP
Even when using standard L3 VPN and route targets importing a RT for spoke VRF sites, the HUB site is not allowed to export again what it has imported from other VRFs. IT can export with a different RT value only "local" routes not learned via import process from VPNv4 table.
This is a consistency check that is performed to avoid to have routes re-injection.
This is equivalent to the above description you cannot re-export what you have learned from other VRFs.
The replication of routes is safe in single node only (local scope)
You need to create an aggregate route one or more then one that covers the Spoke prefixes and then you can advertise these to some other router via eBGP or via MP BGP.
Hope to help
Giuseppe
