EasyVPN problems
Michael Ciulei
Cisco 2811 is VPN concentrator. For two days some users cannot connect to the device with EasyVPN Client.
We have issued the folowing commands and we discovered some errors.
I would like to know what these error means and what to do next.
Also we have a lot of logging inputs like :
002922: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=xx.xx.xx.xx, prot=50, spi=0x9A5BD7FA(2589710330), srcaddr=yy.yy.yy.yy
002923: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=xx.xx.xx.xx, prot=50, spi=0x9A5BD7FA(2589710330), srcaddr=yy.yy.yy.yy
002924: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
connection id=1273, sequence number=7195
002925: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
connection id=1273, sequence number=9303
002926: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
connection id=1273, sequence number=13555
R1-VPN#sh crypto engine accelerator statistic
Errors:
ppq full errors : 1345 ppq rx errors : 0
no buffer : 0 replay errors : 474173
NR overflow : 0 pkts dropped : 1345
R1-VPN#sh crypto engine accelerator ring packet
Device: AIM-VPN/SSL-2
DUMPING THE FIRST ENTRY IN TX, RX, RX POOL
PPQ_CMD_DESCR(0x3F805020): [0x10000, 0x5A65, 0x4420D68C, 0x40098A3C], count=805306371
PPQ_SRC_DESCR(0x3F806A80): [0xF748470, 0x10000588] 0x3F806060[238-RES] 03010554 4420D82C 40098A3C 30000003
F7F3801
0x0016C0[364-FREE] F7BFC81 F78C101 F7ADA81 F7A3581
0x001700[368-FREE] PPQ RING:
cmd ring: head = 238 tail =238
Dumping all the 256 tx cmd ring entries starting from current head
0x3F805020[238-CMD] 00010000 4420D994 4420D964 00000003
0x3F805030[239-CMD] 00010000 4420D994 4420D964 00000003
0x3F805040[240-CMD] 00010000 4420D994 4420D964 00000003
0x3F805050[241-CMD] 00010000 4420D994 4420D964 00000003
0x3F805060[242-CMD] 00010000 4420D994 4420D964 00000003
0x3F805070[243-CMD] 00010000 4420D994 4420D964 00000003
0x3F805080[244-CMD] 00010000 4420D994 4420D964 00000003
0x3F805090[245-CMD] 00010000 4420D994 4420D964 00000003
0x3F8050A0[246-CMD] 00010000 4420D994 4420D964 00000003
0x3F8050B0[247-CMD] 00010000 4420D994 4420D964 00000003
0x3F8050C0[248-CMD] 00010000 4420D994 4420D964 00000003
0x3F8050D0[249-CMD] 00010000 4420D994 4420D964 00000003
R1-VPN#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
paolo bevilacqua
These can be caused by malformed packets or even IOS bugs.
To get to the bottom of the issue you have to work with the TAC.
Lucien Avramov
Level 10
Level 10
There is bug : CSCsv43145 which is a cosmetic issue. Is this impacting your traffic at all? If not you can you try a later version than 12.4(24)T1 to get rid of that error message.
This message could be also coming on the other side of your VPN. If the other side is a cisco router, do you have errors is in the logs as well?
