eBGP Manipulation
kramer977
Hey everyone,
Have a BGP related question. Lets say, Site A (me) has two EBGP links with Site B, two different ISP providers (ISP 1 and 2). The same prefixes are advertised out of both links from the client (Site B). Traffic will be initiated from my side, Site A to Site B. I'm looking to manipulate the traffic outbound to prefer ISP 1 over 2 (primary and secondary).
  1. Plan is to set a higher local preference on the primary ISP link. Create a route map/prefix list and apply the RM on the BGP neighbour, "IN" direction so it's received by our site.
  2. Here is my question. Is it advisable to also create a route map/prefix list and applied it to the "OUT" direction on the same BGP neighbour to ensure the return traffic also follows via the primary ISP 1 link, for eg, I can prepend the neighbourship link on ISP 2 to make it longer so ISP 1 appears shorter and more desirable. Is this advisable or not at all required?
Any other feedback is more than welcome, besides my question
Thanks!
Francesco Molino
You're right. You need to have a rmap in to prefer prefixes from 1 isp over the other.
Then for return traffic to control it, you will need to advertise out your prefixes with a rmap out which will prepend the as over isp2 to make it worst compare to the one received from isp1.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
It will work for traffic between A and B, but not for ISP2 traffic directed to A. Using Backup community from ISP2 is only way to achive using ISP2 as backup.
