EBGP route advertised to IBGP but unable to ping it from IBGP router
Ashwani Pande
Hi Experts,
need help on a lab setup. I am doing BGP between two AS and full mesh iBGP in both AS. Now after checking I am able to reach each other loopback address which I used for peering. I advertised 2 networks to far end AS and I am able to ping them from EBGP router of the other AS but as we know edge router when receives EBGP routes it advertise it one hop inside the network. I can see those routes in iBGP router but when I try to ping them from iBGP router I am unable to ping them? I have changed the next hop address as well between the router that receives that EBGP routes and iBGP router.
Topology is as below I advertised a 2 networks to R1 from R5 and both I can ping from R1 but not from R2.
One network that I advertised is loopback on R5 and other it has learned from R7 through ibgp(RIP).
Look at routing table on R2
Search for the route to 7.7.7.7.
It comes from 1.1.1.1
Search for the route to 1.1.1.1
We got it via Serial0/0
What address does it have?
192.168.1.x/30
We will use this address as source address for the ping 7.7.7.7
Now, on R7, do you have the route for 192.168.1.0/30?
12 Replies 12
a.alekseev
Level 7
Level 7
What nets did you advertise to R5?
I advertised from R5 to R1..R5-->R1. One is the loopback on R5 and other is it has learned through IGP(RIP protocol) which basically R7 advertised to R5.
What nets did you advertise  !!!! FROM R1 TO R5?
Hi From R5 towards R1.
one is 100.100.100.100/32 loopback and one is 7.7.7.7 which is the loopback of R7 as per the diagram.
R5 has learned it through IGP protocol.
Do you understand the difference between two phrases?
"From R1 to R5" and "From R5 to R1"
Does anybody in as200 know about the route to R2?
Yes R5 knows how to reach R1 and R2 as from R5 I can ping both R1 and R2.
Oh...
pls provide the outputs:
sh ip route from R2 and R7
and
from R2
ping 7.7.7.7 source lo0
output of ip route from R2
R2#sh ip route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
D 1.1.1.1 [90/2297856] via 192.168.1.1, 03:03:02, Serial0/0
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.2.2 is directly connected, Loopback0
100.0.0.0/32 is subnetted, 1 subnets
B 100.100.100.100 [200/0] via 1.1.1.1, 00:39:23
168.1.0.0/30 is subnetted, 1 subnets
D 168.1.1.0 [90/2681856] via 172.32.1.2, 03:03:00, Serial0/1
3.0.0.0/32 is subnetted, 1 subnets
D 3.3.3.3 [90/2297856] via 172.32.1.2, 03:03:00, Serial0/1
4.0.0.0/32 is subnetted, 1 subnets
D 4.4.4.4 [90/2809856] via 172.32.1.2, 03:03:02, Serial0/1
6.0.0.0/32 is subnetted, 1 subnets
B 6.6.6.6 [200/1] via 1.1.1.1, 00:39:27
172.32.0.0/30 is subnetted, 1 subnets
C 172.32.1.0 is directly connected, Serial0/1
7.0.0.0/32 is subnetted, 1 subnets
B 7.7.7.7 [200/2] via 1.1.1.1, 00:39:28
122.0.0.0/30 is subnetted, 1 subnets
D EX 122.1.1.0 [170/2681856] via 192.168.1.1, 02:53:17, Serial0/0
192.168.1.0/30 is subnetted, 1 subnets
C 192.168.1.0 is directly connected, Serial0/0
R2#
R2#ping 7.7.7.7 source lo0
Sending 5, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/20/32 ms
R2#
output from R7
B 2.2.2.2 [200/2297856] via 5.5.5.5, 00:41:29
R 100.100.100.100 [120/2] via 10.1.1.2, 00:00:00, Serial0/0
20.0.0.0/30 is subnetted, 1 subnets
R 20.1.1.0 [120/1] via 10.1.1.2, 00:00:00, Serial0/0
5.0.0.0/32 is subnetted, 1 subnets
R 5.5.5.5 [120/2] via 10.1.1.2, 00:00:00, Serial0/0
R 6.6.6.6 [120/1] via 10.1.1.2, 00:00:00, Serial0/0
C 7.7.7.7 is directly connected, Loopback0
10.0.0.0/30 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, Serial0/0
R 122.1.1.0 [120/2] via 10.1.1.2, 00:00:04, Serial0/0
R7#
What are you unable to ping?
yes but I can see you have asked me to ping with source loopback of R2. earlier I was just pinging it from R2 without any source. Does it mean BGP only works if you are pinging with the router ID as a source?
Now I am able to ping R2 from R7 using source as a loopback.
can you please clear why not working in normal ping.
192.168.1.x/30
anuragg
just configure R1<>R2 IBGP neighbor with next-hop-self
