EEM Script not working when manually triggered
abc1235
Level 4
Level 4
Hallo,
I have the below EEM script configured in C1100 router and I am trying to manually trigger it but it is not working. What could it be that I am doing wrong?
event manager applet IP-CHANGE
event none
action 3.0 cli command "enable"
action 4.0 cli command "conf t"
action 5.0 cli command "interface GigabitEthernet0/0/0"
action 6.0 cli command "ip address 162.92.209.14 255.255.255.252"
action 7.0 cli command "no ip route vrf INTERNET 0.0.0.0 0.0.0.0 dhcp"
action 8.0 cli command "ip route vrf INTERNET 0.0.0.0 0.0.0.0 162.92.209.13"
action 9.0 cli command "exit"
R1#event manager run IP-CHANGE
R1#
event manager applet IP-CHANGE-Joy authorization bypass
add this to new EEM and check debug and run.
Joy this is solution I hope
Thanks A Lot
MHM
18 Replies 18
Georg Pauwen
the script looks good. What is the output of:
debug event manager action cli
when you run the script manually ?
Event manager applet IP-CHANGE
event none
action 6.1 cli command "exit"
action 6.2 cli command "conf t"
abc1235
Level 4
Level 4
@Georg Pauwen I get no output on manually triggerring the script, not even with 'debug event manager all'.
@MHM Cisco World Even with the edit, it doesn't work.
dony edit the old one
add new Event with new name and run it manually
Thanks A Lot
MHM
@MHM Cisco World That's what I have done, though action 6.1 should be 'end' then 6.2 'conf t' makes sense. It still doesn't get triggered and no debug message is displayed.
show run
I need to see last EEM you apply
abc1235
Level 4
Level 4
R1#sh run | sec event manager
event none
event none
R1#event manager run IP-CHANGE-Joy
the EEM is not like edit it, it better add new one
Thanks A Lot
MHM
@MHM Cisco World I had turned off the term monitor. Here is partly the output from debug event manager action cli
I already send you solution check below
Command authorization failed.  - you having issue with Authorisation as mentioned my post earlier.
1. how is your authentication (Local or TACACS ?)  - make changes accordingly
BB
abc1235
Level 4
Level 4
Still not working @MHM Cisco World even with the new EEM. This is quite strange since there are even no debug messages.
Thanks A Lot
MHM
This was actually what I needed. I suppose it is because authorization is via TACACS which blocks the commands from being executed. Is that right? Thanks so much for your help 🙂
