EIGRP - adding backup routing
jvanii
I am distributing static routes into eigrp.at two sites.  Specifically, we are using NSX and SRM so that certain VMs have the same IP address at each site, Main and Backup.  At Main, I have two sets of IP addresses with a default route to each subnet.
ip route 10.0.10.0/24 10.20.29.5
ip route 10.0.11.0/24 10.20.29.5
At Backup we have the same subnets, but want to inject route or influence routing via eigrp so that when Main site goes dark/down the following routes would take over automatically.
ip route 10.0.10.0/24 10.20.39.5
ip route 10.0.11.0/24 10.20.39.5
chrihussey
I think the simplest way to accomplish this would be to just administratively weigh the statics at the backup site to something higher than the redistributed statics (170) at the primary site. So then:
ip route 10.0.10.0/24 10.20.39.5 200
ip route 10.0.11.0/24 10.20.39.5 200
As long as the primary routes are active and in the routing table, these routes shouldn't propagate. Once the primary site is offline, the secondary routes would then be advertised.
20 Replies 20
Rejohn Cuares
Level 4
Level 4
Evaluate which one suits your circumstances from the following options.
1.Embedded Event Manager (EEM)
- Use EEM to track the routing table. If the route is not present and learned via EIGRP. EEM installs the static route and redistribute via EIGRP.
2. Static route tracking using IP SLA
- Configure the static routes with IP SLA. The use of IP SLA is to monitor the reachability of a particular host(s). If the host is not reachable, the static route would not be installed in the routing table and thus would not be redistributed to EIGRP.
3. Advertise both subnets from main and backup sites but make sure the backup site has higher EIGRP metric set.
HTH.
Please rate replies and mark question as "answered" if applicable.
I think it would be best to use number 3; setting a higher metric for the backup site routes, but I am not sure what metric to change.  Is not the default metric for eigrp  10000 1 255 1 1500?
So what would I need to change to make this happen?
This is what I have in my config currently
router eigrp 128
 distribute-list static_to_eigrp out static
 network 10.0.0.0
 redistribute static metric 10000 1 255 1 1500
 passive-interface default
 no passive-interface Vlan364
 no passive-interface Vlan368
 eigrp stub connected static summary
It would be best to increase the value of the delay metric from the default to a higher value.
Rick
Rick
Please can you be more specific what higher value might be and how I would add it into the config?
In EIGRP redistribute default metric the second value represents the delay. You currently have this
I would suggest that you change it to this
redistribute static metric 10000 100 255 1 1500
Rick
Rick
But only want to apply the higher metric to these routes, not my whole eigrp redistribution.
If you want to change the metric on some but not all redistributed static routes then you need to use a route map to control your redistribution. In one instance of the route map you would match these routes and redistribute with the higher value of delay and in another instance of the route map you would match the remaining routes and redistribute them with the lower value of delay.
Rick
Rick
Please, could you provide an example. I have yet to use route maps
Here is an example to use to redistribute using route-map:
route-map STATIC_TO_EIGRP permit 10
 match ip address 101
 match ip next-hop 10
 set metric 100000 100 255 1 1500
exit
route-map STATIC_TO_EIGRP permit 20
 set metric 100000 1 255 1 1500
exit
access-list 101 permit ip 10.0.10.0 0.0.0.255 any
access-list 101 permit ip 10.0.11.0 0.0.0.255 any
access-list 10 permit host 10.20.39.5
router eigrp 1
 redistribute static route-map STATIC_TO_EIGRP
HTH,
Meheretab
HTH,
Meheretab
chrihussey
The common way to manipulate redistributed routes is to use route maps. The solution suggested by Chris is very creative (wish I had thought of it) So +5 for it. It achieves the desired result without the complexity of using route maps.
Rick
Rick
Thank you Richard. I appreciate that.
Thank you for your extremely helpful solution and dialogue which give me a better understanding of my network. I went with Chris's solution.
I am glad that our discussion has been helpful and that you have a better understanding of your network as a result of it. The solution from Chris is simple and effective. This reminds us that frequently there may be more than one way to solve a problem. One of the excellent things about these forums is that we have multiple people looking at the issues and potentially suggesting alternative solutions.
Rick
Rick
