EIGRP auto summary
ccnpninja
Is it on or off by default? does it depend on the IOS version?
Jon Marshall
It is on by default. I am not aware that it has changed from IOS version to version.
Edit - beg your pardon. It is on by default up until IOS version 12.2(8)T and then it is off by default.
Jon
Jon Marshall
Jon
ruwhite
Level 7
Level 7
Autosummary has always been on, and probably will always will be on. We've talked about turning it off by default, but it doesn't seem to make a lot of sense--it would probably cause a lot of pain with very little, or no, gain, in the long run.
Russ
Russ
I thought it was always on as well but doesn't this link suggest otherwise ?
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_a1g.html#wp1038925
Jon
Bah! So, apparently, the argument went the other way from the last time I was involved in the conversation. I need eyes in the back of my head, or something.
Anyway, I checked, in and 12.3, it is off by default, rather than on. I can't pinpoint where it changed--I'm asking some of the coders if they know the defect number, etc, but I don't see it right now.
Russ
