EIGRP default route not redistributed when VRF active
mario.jost
Level 3
Level 3
Hi there
problem should be simple to resolve. However, i could not succeed. I have a FlexVPN setup with hub & spoke design. I had to change the configuration from a nonVRF Design into a fullVRF (all interfaces belong to a vrf) design. Since then, the default route is not advertised to spoke routers anymore. Here are some outputs:
roRZ201#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES NVRAM  up                    up
Gi0/0/0.300            172.27.1.9      YES TFTP   up                    up
GigabitEthernet0/0/1   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/2   unassigned      YES NVRAM  up                    up
Gi0/0/2.11             unassigned      YES unset  up                    up
GigabitEthernet0/0/3   unassigned      YES NVRAM  administratively down down
GigabitEthernet0       unassigned      YES NVRAM  administratively down down
Dialer1                212.25.66.107   YES IPCP   up                    up
Loopback2              172.19.0.1      YES manual up                    up
Virtual-Access1        unassigned      YES unset  up                    up
Virtual-Access2        unassigned      YES manual up                    up
Virtual-Access5        172.19.0.1      YES unset  up                    up
Virtual-Template2      172.19.0.1      YES unset  up                    down
roRZ201#show ip eigrp vrf LAN neighbors
EIGRP-IPv4 VR(LAN) Address-Family Neighbors for AS(1)
           VRF(LAN)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   172.19.0.66             Vi5                      14 00:39:34   35  1398  0  36
roRZ201#show ip eigrp vrf LAN topology
EIGRP-IPv4 VR(LAN) Topology Table for AS(1)/ID(172.27.1.9)
           Topology(base) TID(0) VRF(LAN)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 172.19.0.1/32, 0 successors, FD is Infinity
        via 172.19.0.66 (13107200000/9830400000), Virtual-Access5
P 172.19.0.0/24, 1 successors, FD is 163840
        via Connected, Loopback2
P 172.16.220.0/24, 1 successors, FD is 9831055360, tag is 20
        via 172.19.0.66 (9831055360/1310720), Virtual-Access5
P 172.19.0.66/32, 1 successors, FD is 9830400000
        via Rstatic (9830400000/0)
P 172.27.1.0/28, 1 successors, FD is 1310720
        via Connected, GigabitEthernet0/0/0.300
roRZ201#show running-config | include ip rout
ip route vrf LAN 0.0.0.0 0.0.0.0 172.27.1.1
ip route vrf LAN 172.16.0.0 255.240.0.0 172.27.1.1
roRZ201#show ip route vrf LAN | begin Gate
Gateway of last resort is 172.27.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.27.1.1
S     172.16.0.0/12 [1/0] via 172.27.1.1
      172.16.0.0/24 is subnetted, 1 subnets
D        172.16.220.0 [90/76805120] via 172.19.0.66, 00:11:22, Virtual-Access5
      172.19.0.0/16 is variably subnetted, 3 subnets, 2 masks
C        172.19.0.0/24 is directly connected, Loopback2
L        172.19.0.1/32 is directly connected, Loopback2
S        172.19.0.66/32 is directly connected, Virtual-Access5
      172.27.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.27.1.0/28 is directly connected, GigabitEthernet0/0/0.300
L        172.27.1.9/32 is directly connected, GigabitEthernet0/0/0.300
roRZ201#show running-config | begin eigrp
router eigrp LAN
 address-family ipv4 unicast vrf LAN autonomous-system 1
  topology base
   redistribute static
  exit-af-topology
  network 172.16.0.0 0.15.255.255
 exit-address-family
 I tried a whole class B range (as all our devices reside within) as well, but it didnt help. On the spoke side:
roTST01#show ip eigrp vrf LAN topology
EIGRP-IPv4 VR(LAN) Topology Table for AS(1)/ID(172.16.220.3)
P 172.19.0.1/32, 1 successors, FD is 9830400000
P 172.19.0.0/24, 1 successors, FD is 9830481920
        via 172.19.0.1 (9830481920/163840), Tunnel2
P 172.16.220.0/24, 1 successors, FD is 1310720, tag is 20
        via Connected, Vlan10
P 172.19.0.66/32, 1 successors, FD is 9830400000, tag is 20
        via Connected, Tunnel2
P 172.27.1.0/28, 1 successors, FD is 9831055360
        via 172.19.0.1 (9831055360/1310720), Tunnel2
roTST01#show ip route vrf LAN | begin Gate
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.220.0/24 is directly connected, Vlan10
L        172.16.220.3/32 is directly connected, Vlan10
D        172.19.0.0/24 [90/76800640] via 172.19.0.1, 00:12:32
S        172.19.0.1/32 is directly connected, Tunnel2
C        172.19.0.66/32 is directly connected, Tunnel2
      172.27.0.0/28 is subnetted, 1 subnets
D        172.27.1.0 [90/76805120] via 172.19.0.1, 00:12:32
The thing is, it worked before is VRF'ed the hub router. But in my understanding i did everything correct. I hope someone else is spotting my mistake quickly. If you need more output, pls advise.
Help is much appreciated.
mario.jost
Level 3
Level 3
OK i just found this post:
https://www.netcraftsmen.com/using-vrf-lite-eigrp-and-static-routes/
It explains that you have to set a metric when redistributing static routes while using vrf's. As soon as i added a metric, the networks came up immediately.
mario.jost
Level 3
Level 3
