Eigrp default route
Dear All,
     i have two router directly connected routers through 2 links ,the two router are using EIGRP and have a neighbor relationship on both links
     i redistribute the default route in R1 to router R2
                         ----------------------------------------------------------------------Link 1----------------------------------------------------
                   R1        R2
                         ---------------------------------------------------------------------link 2------------------------------------------------------
why i see only one default route in R2 through one link only !!!!
i redistribute another static route and  R2 has those route through both links
why the default appear through one link only
cadet alain
Can you post the output for sh ip eigrp topology on R2 as well as sh run | s eigrp on both routers.
Regards.
Alain
Hi Cadet ,
     Thanks for your considration
     kindly find attached
P.S if i remove
distribute-list 10 out BVI1 on R1
the other static route appear on the R2 through both links
Thanks again for yout time
