02-07-2019 07:23 AM - edited 02-07-2019 07:52 AM
Having a problem with a 2 neighrbors losing their EIGRP adjacency:
2951 gi0/11.2 >>>>>>>>>>> 3850 gi1/0/45
They are connected directly to each other but sometime last night it started to lose the adjacency. I went as so far as to statically configure them as neighbors which didn't fix it. The 2951 has 2 other EIGRP neighbors which it doesn't drop connectivity between, its just between itself and the 3850. I do see the Q count as 1 on both sides and debug shows, what looks to me, like the 3850 stops sending packets back to the 2951.
I am also seeing weird routing issues on some of the VLANs on the 3850 as well, some are passing traffic while others aren't. I tried power cycling the 3850 but it made no difference. I have read all types of horror stories about 3850 bugs but no idea if this just another issue with a 3850. Its currently on 16.3.6 and wondering if an upgrade might help at this point.
router eigrp 3000 distribute-list 90 out Tunnel1 network 10.1.100.0 0.0.0.255 network 10.1.200.0 0.0.0.255 network 10.119.2.0 0.0.0.255 redistribute static route-map lab neighbor 10.119.2.1 GigabitEthernet0/1.2 eigrp router-id 10.119.2.2
router eigrp 3000
network 10.119.2.0 0.0.0.255 neighbor 10.119.2.2 Vlan2 eigrp stub connected summary snmp-server enable traps eigrp snmp-server enable traps ipsla snmp-server enable traps syslog
010173: Feb 7 20:27:21.553: EIGRP: Sending UPDATE on Gi0/1.2 - paklen 0 nbr 10.119.2.1, retry 5, RTO 5000 tid 0 010174: Feb 7 20:27:21.553: AS 3000, Flags 0x1:(INIT), Seq 9164/124 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1 010175: Feb 7 20:27:21.565: EIGRP: Received UPDATE on Gi0/1.2 - paklen 0 nbr 10.119.2.1 010176: Feb 7 20:27:21.565: AS 3000, Flags 0x1:(INIT), Seq 124/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1, last received seq 124, out of sequence, this seq 124 010183: Feb 7 20:27:24.813: EIGRP: Received HELLO on Gi0/1.2 - paklen 26 nbr 10.119.2.1 010184: Feb 7 20:27:24.813: AS 3000, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1 010185: Feb 7 20:27:24.813: EIGRP: Received Peer Info from AS 203882497(10.119.2.1), old info, ignored 010186: Feb 7 20:27:25.217: EIGRP: Sending HELLO on Gi0/1.2 - paklen 20 nbr 10.119.2.1 010187: Feb 7 20:27:25.217: AS 3000, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
02-07-2019 01:10 PM
02-07-2019 02:01 PM
Barring any possibility of a router with same Router-ID somewhere in your network redistributing routes, it's likely that the 3850 is getting a feedback, which could also attributed to Layer 2. I can't definitely pin-point, but I would just suggest reviewing your network at both Layer 2 and 3 including the Spanning root for your VLANs. It helps to make a network deterministic.
