02-07-2008 11:42 AM - edited 03-03-2019 08:37 PM
How do you trouble shoot this problem, I've got a couple of L3 4500's and a couple of 7200's for VPN tunnels
02-07-2008 12:10 PM
Stuck in active means the router/L3 switch is actively qureying neighbors for a route to 10.0.0.0/8 but is not getting replies from all neighbors.
Check for congested links which would delay the responses or a router under a very high CPU load which again coudl delay a response.
Also have a look at this link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008010f016.shtml
Jon
02-07-2008 12:21 PM
I's just this one route that the switches are complaining about
Etherchannel between the two 4500's,
Multiple Vlans between the Switches that they are neighboring on
USL3ATL002#show int port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0012.01f7.8bc0 (bia 0012.01f7.8bc0)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 10/255, rxload 6/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is N/A
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/1 Gi1/2
Last input 00:00:02, output never, output hang never
Last clearing of "show interface" counters 00:03:59
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 52803000 bits/sec, 14242 packets/sec
5 minute output rate 84017000 bits/sec, 15451 packets/sec
3743777 packets input, 1630954897 bytes, 0 no buffer
Received 17174 broadcasts (3175 multicast)
4089092 packets output, 2685834808 bytes, 0 underruns
0 lost carrier, 0 no carrier
USL3ATL002#show proce cpu
CPU utilization for five seconds: 12%/1%; one minute: 15%; five minutes: 13%
USL3ATL002#show ip eigrp top act
IP-EIGRP Topology Table for AS(2)/ID(10.229.248.3)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
A 10.0.0.0/8, 1 successors, FD is 259584
1 replies, active 00:01:53, query-origin: Multiple Origins, retries(1)
via 10.10.1.102 (260096/259840), Vlan30, serno 5549636
via 10.11.1.2 (Infinity/Infinity), r, Vlan11, serno 5549635
via 10.11.2.2 (260096/259840), Vlan12, serno 5549580
via 10.11.200.3 (260096/259840), Vlan200, serno 5549578
via 10.1.1.102 (260096/259840), Vlan100, serno 5549579
02-07-2008 12:26 PM
Okay, it would be a good idea to read the attached link. From your output above
The same , r, means USL3ATL002 is still waiting on a reply from 10.11.1.2.
So you need to look at 10.11.1.2.
Jon
02-07-2008 12:52 PM
This is the some output from the other 4500
Low processer utilization low bandwidth usage
USL3ATL001#show process cpu
CPU utilization for five seconds: 11%/1%; one minute: 12%; five minutes: 12%
Hardware is EtherChannel, address is 0012.01f7.8c00 (bia 0012.01f7.8c00)
MTU 1552 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 6/255, rxload 6/255
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 29w0d
5 minute input rate 50585000 bits/sec, 13524 packets/sec
5 minute output rate 48858000 bits/sec, 13765 packets/sec
110605218922 packets input, 68855073215747 bytes, 0 no buffer
Received 296919263 broadcasts (240619098 multicast)
120619525229 packets output, 68403553984381 bytes, 0 underruns
Why is it only this one route that the switches are complaining about?
Is this static route 10.0.0.0 with a metric 200 messing up the routing?
router eigrp 2
redistribute static
network 10.0.0.0
default-metric 100000 10 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
ip route 0.0.0.0 0.0.0.0 10.1.2.1
ip route 10.0.0.0 255.0.0.0 Null0 200 <----
ip route 10.5.5.0 255.255.255.0 10.1.80.1
