EIGRP failover
J2NoomSai_2
We have two routers, A and B. THey both configure with HSRP so one is active and one is standby. If A down, B will be active. But I need help to configure EIGRP for failover. Let's say if only the circuit on Router A down but not the router, how can the router go through router B?
Sai
Giuseppe Larosa
Hello Sai,
This is exactly the job of a routing protocol like EIGRP no special config is needed.
You need to have EIGRP running on the link where HSRP is running.
If you want a further link between them with EIGRP running
EIGRP running on a link = network command for the IP subnet of the link under router eigrp
suppose your lan interfaces and serial links are in net 10.1.0.0/16:
You need on both routers:
router eigrp 100
network 10.1.0.0 0.0.255.255
Hope to help
Giuseppe
Thanks Giuseppe. So after certian amount of age time, it will route to router B, if can not route to Router A?
Hello Sai,
yes EIGRP convergence is very fast in the order of few seconds (2-3) to be added to the time the router requires to detect its serial interface is down
(line protocol down needs to fail 3 keepalives :up to 30 seconds).
Notice that you can use HSRP tracking of the serial interface so that active router becomes router B if RA's serial interface fails
RA:
int fas0/0
standby 10 priority 105
standby 10 track ser0/0
standby 10 preempt
RB:
int fas0/0
standby 10 preempt
Hope to help
Giuseppe
