EIGRP & looping packet
BeechLiam
I have 2 4506E sup2+ connected with a number of vlans configured for HSRP. I changed to of the vlans subnet masks, verified the configuration on both, and now i cant ping the HSRP VIP address on both of these vlans.
When tracing & Showing ip route, to one of the physical interfaces it loops between vlans instead of displaying it as direclty connected.
Any ideas beside clearing the EIGRP.
Jul 21 16:03:51 gmt: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=10.12.11.11, dst=152.x.x.x, hl=20, tl=84, prot=1, sport=0, dport=0
in=Vlan65, nexthop=10.72.105.3, out=Vlan64
options=none
-Process= "IP Input", ipl= 0, pid= 77
-Traceback= 10A3CC28 10A3CECC 10A3EA88 10A3F8E8 10A3D438 10A2E42C 10A2E8E8 10A2D
670 10A2D8D4 10A2DB98 10626460 1061DC68
7 Replies 7
vmiller
Level 7
Level 7
Did you clear IP routes ?
Worst case, you may need to do a reload,
or a power cycle.
neilobrien
After changing the mask of the VLAN interfaces, is the hsrp address still in the subnet? Did you change the routing protocol to reflect the new mask for the subnets?
Or are there any routes/helpers that are attempting to forward to an ip address that was outside the subnet but now is inside after the mask change??
I have verified the HSRP is still in the subnet. and routes and helpers.
The EIGRP is a stub with no auto-summarize, the subnet is subnetting down to 6 vlans. but I have it advertised as a full /24. the EIGRP protocol keep trying to establish new adjacency for the vlan , stating the vlan is down but the vlan is up up.
would it be possible to post a config??
Both vlan interface are showing as UP UP ,even though the EIGRP logs specify the vlans are down.
SW1
interface Vlan4
ip address 152.62.76.66 255.255.255.192
standby ip 152.62.76.65
standby preempt
interface Vlan5
description Prod_servers
ip address 152.62.76.130 255.255.255.192
standby ip 152.62.76.129
standby preempt
Router EIGRP 0
NETWORK 152.62.76.0 255.255.255.0
no auto-summary
eigrp stub connected summary
sh log
Jul 22 10:26:15 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.67 (V
lan4) is down: Interface Goodbye received
Jul 22 10:26:20 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.67 (V
lan4) is up: new adjacency
Jul 22 10:26:41 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.131 (
Vlan5) is down: Interface Goodbye received
Jul 22 10:26:45 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.131 (
Vlan5) is up: new adjacency
SW2
interface Vlan4
ip address 152.62.76.67 255.255.255.192
standby priority 50
standby preempt
interface Vlan5
ip address 152.62.76.131 255.255.255.192
standby priority 50
standby preempt
Router EIGRP 0
network 152.62.76.0 255.255.255.0
no auto-summary
sh log
Jul 22 10:27:38 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.66 (V
lan4) is down: retry limit exceeded
Jul 22 10:27:41 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.66 (V
Jul 22 10:28:04 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.130 (
Vlan5) is down: retry limit exceeded
Jul 22 10:28:07 gmt: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 152.62.76.130 (
Hi - why do you have them configured as stubs. this is most likely your problem. Stub routers should only be "spoke" routers on the edge of a network.
The eigrp errors are telling you that EIGRP is tearing down the adjacency itself (goodbye packets). When a router is configured as a stub, it advertises a summary route, which resets the neighbours. I'd say your routers are in a little loop of sorts.
remove the stub commands and the neighbours should come up and stay up.
The 4506 switch sup + 2 only supports stub eigrp. The preferred option was to upgrade to full EIGRP. The stub command can stay, but I cleared the ip eigrp neighbors on the 4506 , which had resolved the loop issue. but I have to put a static on the Gateway router for the network as the stub looks like it wont advertise the route to the gateway for the 152.62.76.0 network.
In the meantime , I have the fix. Clearing the ip eigrp neighbors and now the route is learned as a /26 instead of a /27 as previously.
Thanks for the help folks
