eigrp redistribution
sadam2006
dear all
if i am going to redistribute a routing protocol into eigrp, and i have a delay metric of 2ms how i am going to insert it in the redistribution command the dealy of the interface is a unit of 10-micros second as cisco tell, please help
pkhatri
Level 11
Level 11
The redistribute command for EIGRP takes a delay parameter in 10s of microseconds. Therefore, for a delay of 2ms, you need to set the delay parameter to 200. That means 200 x 10 microseconds, which gives you 2 seconds.
Paresh
PS> Pls do remember to rate posts.
