EIGRP unequal cost load balance
gatlin007
Level 4
Level 4
I’m attempting to configure unequal cost load balancing with EIGRP and haven had any luck. In the following output I’m attempting to load balance between fa0/3 and fa0/5 for the 5.5.5.5 host. If I make the metrics equal it does it no problem. As soon as I change the metric it only populates one route in the routing table.
Switch#
Switch#show ip pro
*** IP Routing is NSF aware ***
Routing Protocol is "eigrp 100"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 4
Redistributing: eigrp 100
EIGRP NSF-aware route hold timer is 240s
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
0.0.0.0
Routing Information Sources:
Gateway Distance Last Update
2.2.2.2 90 00:01:29
1.1.1.2 90 00:01:29
Distance: internal 90 external 170
Switch#
Switch#
Switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, FastEthernet0/5
2.0.0.0/24 is subnetted, 1 subnets
C 2.2.2.0 is directly connected, FastEthernet0/3
5.0.0.0/32 is subnetted, 1 subnets
D 5.5.5.5 [90/156160] via 2.2.2.2, 00:01:39, FastEthernet0/3
10.0.0.0/32 is subnetted, 2 subnets
C 10.0.0.3 is directly connected, Loopback0
D 10.0.0.1 [90/156160] via 2.2.2.2, 00:01:55, FastEthernet0/3
Switch#
Switch#
Switch#
Switch#show ip ei top det
IP-EIGRP Topology Table for AS(100)/ID(10.0.0.3)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 5.5.5.5/32, 1 successors, FD is 156160, serno 6
via 2.2.2.2 (156160/128256), FastEthernet0/3
via 1.1.1.2 (284160/256256), FastEthernet0/5
P 1.1.1.0/24, 1 successors, FD is 28160, serno 15
via Connected, FastEthernet0/5
P 2.2.2.0/24, 1 successors, FD is 28160, serno 4
via Connected, FastEthernet0/3
P 10.0.0.3/32, 1 successors, FD is 128256, serno 1
via Connected, Loopback0
P 10.0.0.1/32, 1 successors, FD is 156160, serno 5
Switch#
Switch#show run | be router ei
router eigrp 100
variance 4
network 0.0.0.0
no auto-summary
Kevin Dorrell
Level 10
Level 10
You are being caught by the "feasible successor" rule. At first sight, it may look like the two routes for 5.5.5.5 should balance, but they do not. Look in the topology table, and you see that only one is a successor. This is because the next hop via 1.1.1.2 is 256256 away from the destination. But you are only 156160 from the destination via your best route. Therefore you are closer to the destination than 1.1.1.2 is. So 1.1.1.2 cannot be a successor, to avoid loops.
The only way you can fiddle this so that it works is to artificially make your best route worse than 256256. Then 256256 would become a feasible successor.
Kevin Dorrell
Luxembourg
limtohsoon
To qualify as a feasible successor, a next-hop router must have an advertised distance (AD) less than the feasible distance (FD) of the current successor route.
In your case, the AD of router 1.1.1.2 is 256256, which is NOT less than the FD of your current successor 2.2.2.2 (FD=156160).
Only paths that are feasible can be used for load balancing. The two feasibility conditions are as follows:
(1) The local best metric (the current FD) must be greater than the next router best metric (the AD) learned from the next router.
(2) The variance X the local best metric (the current FD) must be greater than the metric (the FD) through the next router.
If both of these conditions are met, the route is called feasible and can be added to the routing table.
In your case, the path via 1.1.1.2 is not considered for load-balancing because it does not satisfy condition (1), though it satisfies condition (2).
Hope this helps.
Thank you.
B.Rgds,
Lim TS
Thanks guys!!!
I adjusted it as per your advice and it worked great.
Chris Gatlin
D 5.5.5.5 [90/276160] via 2.2.2.2, 00:02:55, FastEthernet0/3
[90/284160] via 1.1.1.2, 00:02:55, FastEthernet0/5
D 10.0.0.1 [90/276160] via 2.2.2.2, 00:02:55, FastEthernet0/3
Switch#
Switch#
P 5.5.5.5/32, 1 successors, FD is 276160, serno 10, Stats m(17)M(17)A(17)c(1)
via 2.2.2.2 (276160/248256), FastEthernet0/3
P 1.1.1.0/24, 1 successors, FD is 28160, serno 2
P 2.2.2.0/24, 1 successors, FD is 28160, serno 5
P 10.0.0.1/32, 1 successors, FD is 276160, serno 9
Switch#
router eigrp 100
variance 2
offset-list 0 in 120000 FastEthernet0/3
network 0.0.0.0
no auto-summary
