EIGRP Unequal-Equal Load Balance problem
lveraza
I have this connection with these routers:
RA(Internet) - RB - RC - RD(Internet)
Between RA and RB we have 2 links, 1536 each
Between RB and RC we have 2 links, 1024 and 2048
Between RC and RD we have one link, 1536
Now we have configured bandwidth 1024, RB and RC because by default we have Load - balance, but when we want Load-balace with unequal links, the traffic to Internet from RB goes trough RC, it does not use its 2 link.
Do you know what can i do ?
Best regards, Luis
5 Replies 5
Kevin Dorrell
Level 10
Level 10
Did you put a variance command under the EIGRP in routers B and C? If not, try variance 2, and put back the links to their original bandwidth values. That should allow them to do unequal load balancing.
Kevin Dorrell
Luxembourg
Thanks Kevin,
Yes, i put Variance 2 command, and their original bandwidth values, but traffic from RouterB goes trough RouterC.
I want to change it.
regards, Luis
On router B, could you do a show eigrp topology please? That might give a better clue as to what is going on.
Also a show eigrp neighbor. Are RA and RB actually forming an adjacency?
Kevin Dorrell
Luxembourg
Kevin,
I´ll get this information tonight,
Because, i couldn´t change last night.
Regards, Luis
Kevin,
Because, i couldn´t change anything last night, didn´t works properly.
Regards, Luis
