EIGRP with DMVPN
yuhuiyao
Why there is a need to change the tunnel interface bandwidth when running EIGRP with DMVPN?
Giuseppe Larosa
Hello Yuhui,
this is made to influence the choice of best path to primary hub (preferred) in comparison to secondary hub (less preferred)
the lowest bandwidth in path is part of EIGRP metric calculation
256 * (sum of delays in 10s of microseconds)
bw component is the inverse of the smallest BW in the path in kbps multiplied to 256
256 * 10^7/Lowest_BW[Kbps]
Hope to help
Giuseppe
