eigrp withdrawing method
Arun
There is no flags in eigrp update messages to withdraw the routes.How the neighbors are communicated about invalid routes?
Nagendra Kumar Nainar
EIGRP will update the same prefix with infinity metric. Any router on receiving a prefix with infinity metric will consider it as withdraw and remove from local table.
-Nagendra
-Nagendra
Hi Nagendra,
Thanks for your reply..I seen this in my lab and wanted to confirm with the experts.. thanks again.. could you please check and answer the below query as well..
https://supportforums.cisco.com/comment/9670296#comment-9670296
Current eigrp version is 2.. is there any major difference between version 1 and 2.. Couldnt find the answer in the web..
