EIGRP
saquib.tandel
EIGRP supports unequal loadbalancing but applying variance command causes packet drops.
I have done as of this url
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml#topic1
Site_A connects to Site_B over GRE Tunnel with two different media and different bandwidth using eigrp as routing protocol.
Both GRE Tunnels terminates on Same Router.
Connection= Site_A to Site_B
Media = Ethernet using SatelliteLink
Bandwidth = 1MB
Type : GRE Tunnel
Media = Ethernet Using service Provider
Bandwidth = 2.5MB
Type : GRE Tunnel
If Both Tunnels are up then packet drops are seen, if anyone tunnel is up there is no packet drops.
Configuration of * Site_A *
interface Tunnel1
description "VSAT Link"
ip address 192.168.1.1 255.255.255.252
keepalive 3 10
tunnel source 10.10.10.2
tunnel destination 172.17.17.2
interface Tunnel2
description "2MB Link"
ip address 192.168.2.1 255.255.255.252
keepalive 3 10
tunnel source 192.168.100.2
tunnel destination 10.100.200.2
router eigrp 1
network 192.168.1.0 0.0.0.3
network 192.168.2.0 0.0.0.3
Any help
ST
18 Replies 18
Giuseppe Larosa
Hello Saquid,
to perfom not equal cost load balancing you should add:
int tunnel 1
bandwidth 1000
int tunnel 2
bandwidth 2500
router eigrp 1
variance 3
in this way you have more traffic on the more capable tunnel and less traffic on tunnel 1
with your current configuration you are trying to do equal cost load balancing and you can see output drops on tunnel 1
Hope to help
Giuseppe
After performing some bandwidth test ; i am getting 512K on Link1 and 2MB on Link 2.
I modified the tunnel config I get same packet drops.
int tunnel 1
bandwidth 512
int tunnel 2
bandwidth 2000
router eigrp 1
variance 4
On Cisco Documentation is there anywhere it states to have unequal loadbalancing you need to have a bandwidth statement.
Any input.
Hello Saquib,
EIGRP metric depends from several factors but with default settings ( k values) it depends from:
cumulative delay on path
inverse of smallest BW on path
see for example:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml
in your case you need to change the parameters otherwise they are seen as equal cost paths
Hope to help
Giuseppe
Hello Giuseppe
I have amended the config as your input but there is still packet drops.
is Variance  4 correct when bandwidth is 2MB and 512K
ST
Hello Saquib,
yes variance 4 should be fine.
Do you see packet drops only on tunnel1 or also on tunnel2 or on physical interfaces?
May  you post sh int tunnel1, sh int tunnel2 and sh int of physical interface?
Hope to help
Giuseppe
Hello Guissepe
Please see the output
CTR_Router#sh int tunnel 2
Tunnel2 is up, line protocol is up
  Hardware is Tunnel
  Description: "2MB Link"
  Internet address is 192.168.2.1/30
  MTU 1514 bytes, BW 2000 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 192.168.100.2, destination 10.100.200.2
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2754
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 4000 bits/sec, 7 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     13250144 packets input, 921421194 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     7854559 packets output, 1694467458 bytes, 0 underruns
     0 unknown protocol drops
CTR_Router#sh int tunnel 1
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Description:"VSAT Link"
  Internet address is 192.168.1.1/30
  MTU 1514 bytes, BW 512 Kbit, DLY 500000 usec,
  Keepalive not set
  Tunnel source 10.10.10.2 (GigabitEthernet0/1.12), destination 172.17.17.2
  Tunnel TTL 255
  Last input 00:00:00, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 122622
     24847170 packets input, 638404318 bytes, 0 no buffer
     23024994 packets output, 780010052 bytes, 0 underruns
CTR_Router##sh int gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is JK98980 Ethernet, address is 005r.50bb.88k1 (bia 005r.50bb.88k1)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Input queue: 0/75/173/0 (size/max/drops/flushes); Total output drops: 0
  Output queue: 0/40 (size/max)
  5 minute input rate 18000 bits/sec, 17 packets/sec
  5 minute output rate 14000 bits/sec, 17 packets/sec
     341493206 packets input, 1211689319 bytes, 0 no buffer
     Received 2528374 broadcasts, 0 runts, 0 giants, 27 throttles
     1340 input errors, 0 CRC, 1 frame, 0 overrun, 1339 ignored
     0 watchdog, 0 multicast, 0 pause input
     342812417 packets output, 276179600 bytes, 0 underruns
     135928 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Hello Saquib,
the exit points are two vlan subinterfaces of giga0/1 ?
and I see that the tunnel declares a bandwidth of 8000 kbps have you removed the bandwidth commands?
What kind of device is this?
I guess an ISR, 2800 series
what IOS image is running on the box?
sh ver | inc image
Hope to help
Giuseppe
I have not removed the bandwidth command from the tunnels.
sh ver | inc image
System image file is "flash:c2800nm-adventerprisek9-mz.124-21.bin"
I have Two Interfaces on the Router, so both Internet links are terminated as sub-interface.
Giga 0/0 connects to LAN
Giga0/1 configured as sub-interface for Internet links.
Its a Cisco 2851 (revision 53.51) with 249856K/12288K bytes of memory.
2 Gigabit Ethernet interfaces
2 Virtual Private Network (VPN) Modules
I am still stuck on this issue, any help.
Hello Saquid,
I would try with a different IOS image: take a 12.4T image with same feature set and let's see if there are any changes.
in the log of  router there are messages regarding changes of state of the two tunnels, I see in first post that you have configured tunnel GRE keepalive. Are the tunnels stable?
Hope to help
Giuseppe
Hi Guislar,
Are you suspecting an IOS Issue.
If I have Either of One Tunnel UP then all is working Ok but when both tunnels are up then I get packet loss.
Due to above I configured keepalive.
For my existing IOS there are no known EIGRP bugs.
What you suggest.
I have changed the Router with 12.4 IOS but still the same packet drop.
System image file is "flash:c2801-spservicesk9-mz.124-11.T.bin"
Please help.
ST
Mohamed Sobair
Level 7
Level 7
Hi ST,
First the Variance command doesnt necessarly need the bandwidth statment at the interface to be modified.
The Idea is that:
Eigrp default to loadbalance across 4 equal cost paths by default, to perform un equal cost loadbalancing , then you need the variance command, How its calculated? Eigrp calculates the total metric (FD) to the reach a destination Network, IF FDs for both paths are the same then loadbalancing shoud take place, if not, then you need the variance command to place the second path in the routing table.
However, 1- with all your current config, and the variance applied, what is the default CEF loadbalancing method on the router? If its per-packet loadbalance, then disable it and let it be per-destination as per packet could result in packets recieved the destination out of order.
2- remove the tunnel keep alives from both tunnel interfaces.
3- configure (tunnel path-mtu-discovery) at both tunnels on all routers
let us know if this help,
Mohamed
Dear Mohammed
I have done the following
1)     No ip cef
2)      No tunnel keep-alives
3)      ip mtu 1400
But still have packet loss when both tunnels are up.
Hope to get some help.
ST
