Enable DMZ interface on cisco 836/837
wgaal1
Is it possible to enable the ethernet 2 interface on 836/837 like on the 830 to use as a DMZ interface ?
b.hsu
Level 5
Level 5
You will not be able to configure the fast ethernet interfaces with ip addresses. These interfaces are
only layer 2 switch ports and only allows settings of the following parameters:
* Speed
* Duplex
- for Enabling Managed LAN Switch
This would be possible with a 1700 series router and the 4 port switch interface. You could define a vlan for each port and create like that 4 interfaces. However, from a security point of view it remains a switch. There might be known or unknown possibilities to connect from one interface to the other without passing the routing engine.
tekha
Level 3
Level 3
Of course you can.
As you can see from this post, (http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=0ysv8znpz1.SJ1B?page=netprof&forum=Network%20Infrastructure&topic=Getting%20Started%20with%20LANs&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd7a8cc) Simon Bell and I are using two diffent IOS versions, and both seem to work fine.
Simon on a 837 and me on a 831, both routers get a new routed interface called Ethernet2.
