enable password
engbandar
hi gentleman
i have switch on other branch i can not ping this switch but the rest of switch i can ping it when i want to go on enable mode there is no password set ?
my question can i but enable password remotely note the branch is empty no person there
thanks
5 Replies 5
Leo Laohoo
Yes
Ivan Krimmel
Level 7
Level 7
Hi engbandar
if you have console access to the remote switch this should be easy. If you have no console access but only telnet access, which most likely requires a password but none is set, then I am afraid you'll need to get console access first.
HTH.
engbandar
i have only telnet access but enable password not set this is the massage showing when i tray to access to enable mode
you need a console access then, as thre's no way to sneak in to the enable mode remotely. Alternatively via reverse telnet you could get the same console access remotely, but you'll need a terminal server solution for that.
engbandar
thank you
