Encryption over Frame-Relay
pkapoor
Level 3
Level 3
I have two sites connected via a dedicated / private FR circuit. Several servers on one side talk to about 2 servers on the other site. I need to encrypt the data over this circuit and the encryption should be setup on the endpoint routers themselves.
Communication is bi-directional i.e. sessions can be initiated from servers on either side. The routers will also have to NAT the IPs of the servers.
I have never setup encryption over FR (I know Cisco CET w/ GRE but we're looking for options). Can anyone guide me in the right direction?
Thanks.
mmorris11
Level 4
Level 4
Is ipsec an option for you? If you use that, as a l3 technology it takes the l2 (frame relay) out if the picture.
http://www.cisco.com/en/US/customer/tech/tk583/tk372/tsd_technology_support_protocol_home.html
HTH, pls rate!
ajagadee
Paras,
Please refer the below URL to set up IPSEC Tunnel between two sites:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094634.shtml
In case if you want multicast traffic to flow across the tunnel, you need to do Ipsec Over GRE.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800a43f6.shtml
Let me know if it helps.
Arul
