Error cisco 898
I get this error when I connect console to cisco 898
*Feb 23 22:23:50.435: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x40, offset 0x00000007 on I2C bus 1
*Feb 23 22:23:51.507: %PQ3_I2C-3-I2C_ERROR: I2C error at bus no. 1, device address 0x40: I2C slave device not found.
-Traceback= 6E474F4z 5759058z 575BBF8z 5AD260Cz 5AD2274z 60A7AB8z 60A7AE8z 5DD784Cz 5DD2904z 5DD60E8z 5FFB0F0z 5FE2020z
*Feb 23 22:23:51.507: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x40, offset 0x0000000A on I2C bus 1
*Feb 23 22:23:51.983: %PQ3_I2C-3-I2C_ERROR: I2C error at bus no. 1, device address 0x40: I2C slave device not found.
-Traceback= 6E474F4z 5759058z 575BBF8z 5AD260Cz 5AD2274z 5DBC0F8z 5DBC374z 5DD2EA0z 5DD611Cz 5FFB0F0z 5FE2020z
*Feb 23 22:23:51.983: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x40, offset 0x00000007 on I2C bus 1
*Feb 23 22:23:53.055: %PQ3_I2C-3-I2C_ERROR: I2C error at bus no. 1, device address 0x40: I2C slave device not found.
*Feb 23 22:23:53.055: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x40, offset 0x0000000A on I2
and I attach the status of "p o e" also it have orange color .
5 Replies 5
Leo Laohoo
RMA.
The router is dead.
what is RMA.  ?
@mohamedabdelalim wrote:
what is RMA.  ?
Contact Cisco TAC and organize for an RMA.
Tell them the router may be dead.
RMA means Return Merchandise Authorization, basically a procedure to return your router. Where did you buy it ?
could also be a bug. I found the one below. Make sure you run something like the recommended release 15.7.3M8 MD.
%MAINBOARD-3-I2CRW_ERROR: Write failure - Device @ 0xE0
CSCur64583
Description
Symptom:
%MAINBOARD-3-I2CRW_ERROR: Write failure - Device @ 0xE0, offset 0x00000000 on I2C bus 1
Conditions:
Steady state operations
Workaround:
None
Further Problem Description:
None
