ERSPAN on ASR1002
jayuk7601
Beginner
Beginner
We want to do a ERSPAN on an ASR1002 and also want to understand how much data goes through a partciluar interface.
If we only had the cli how can we ontain the throughput on the device so that i can tell us what it has served through over say a 24 hour period?
Does the ASR1002 fully support ERSPAN and if we wanted to filter a particular service / protocol to Span - this is possible?
Rob
Akash Agrawal
You can go through below CCO and check if it helps
http://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/116212-configure-asr-00.html
Akash
