mitchen
Explorer
Establishing 3G connectivity using CISCO887VAG+7-K9
We have a fixed IP address 3G data SIM which we intend to use as backup for our ADSL connectivity using a CISCO887VAG+7-K9 router.  (We have previously implemented similar using the older CISCO887G-K9 router without any issues)
The problem is, we don't seem to be able to establish 3G connectivity with this new router.  Our service provider assures us that the SIM card is active (although they have seen no connection attempts from us on their RADIUS server)
The router is running IOS version 15.1(4)M4 and the following is the relevant config we have used:
cellular 0 gsm profile create 1 $apn chap $user $pass ipv4
chat-script INTERNET "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
controller Cellular 0
interface Cellular0
no ip address
ip mtu 1452
ip flow ingress
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 60
dialer in-band
dialer pool-member 1
async mode interactive
interface Dialer1
ip address negotiated
ip access-group $acl in
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string INTERNET
dialer persistent
dialer-group 1
ppp chap hostname $user
ppp chap password $pass
no cdp enable
access-list 1 permit any
dialer-list 1 protocol ip permit
sh cellular 0 profile
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = $apn
Authentication = CHAP
Username: $user
Password: $pass
* - Default profile
Configured default profile for active SIM 0 is profile 1.
sh cellular 0 network
Current Service Status = Emergency Only, Service Error = None
Current Service = Invalid
Packet Service = None
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = GBR, Network = 3 UK
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 20
Location Area Code (LAC) = 51
Routing Area Code (RAC) = 51
Cell ID = 17581
Primary Scrambling Code = 330
PLMN Selection = Automatic
sh cellular 0 security
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Can anyone tell me what we are doing wrong and how to correct it so that we can establish connectivity?
Thanks.
29 REPLIES 29
mitchen
Explorer
Shameless bump for this one!
Has anyone got any ideas where we are going wrong with the configuration of this router?
dpocana78
Beginner
In a first sight, it looks fine.
The only thing I can see is the encapsulation on the Dialer interface.
In this model modem, the encapsulation that works is SLIP not PPP. So interface configuration should be:
interface Dialer1
ip nat outside
encapsulation slip
load-interval 30
dialer pool 1
dialer persistent
On the other hand, are you sure that your ISP uses CHAP instead of PAP?
About the user/pwd negotiation, don't worry about unconfigure on the Dialer1 interface as it uses the profile to connect.
Daniel.
Hi Daniel,
thanks for the suggestion - I tried changing the dialer interface encapsulation to SLIP but still no joy I'm afraid.
The ISP definitely uses CHAP as they have confirmed this with me already.
Any other suggestions on this would be welcome though!
Hi Mitchen,
Checking it again, it seems there's also a coverage problem and :
Cell ID = 17581
On the other hand, you should also configure "line 3" as it is the interface which really stablish the communication.
You should configure:
line 3
exec-timeout 0 0
script dialer INTERNET
modem InOut
no exec
transport input all
About the CHAP/PAP, according to my ISP, it should be CHAP, but only works with PAP... ;-)
If you still have problems, can you put the output of the debugs:
     - debug cellular 0 messages
     - debug chat
     - debug ppp packet
Daniel.
Hi Daniel,
thanks for the further assistance.  Actually the show cellular 0 network output has changed slightly since i originally posted (but still doesn't offer me much encouragment!):
Current Service Status = No service, Service Error = None
Current Service = Circuit Switched
Routing Area Code (RAC) = 255
Cell ID = 0
Primary Scrambling Code = 0
I already had the "line 3" config that you mentioned, apologies, I should have included that in my original post.
Debug ppp packet didn't return anything, the other debugs are shown below:
debug chat
Oct  8 15:32:58.894: CHAT3: Attempting async line dialer script
Oct  8 15:32:58.894: CHAT3: Dialing using Modem script: INTERNET & System script: none
Oct  8 15:32:58.894: CHAT3: process started
Oct  8 15:32:58.894: CHAT3: Asserting DTR
Oct  8 15:32:58.894: CHAT3: Chat script INTERNET started
Oct  8 15:32:58.894: CHAT3: Sending string: AT!SCACT=1,1
Oct  8 15:32:58.894: CHAT3: Expecting string: OK
Oct  8 15:33:58.894: CHAT3: Timeout expecting: OK
Oct  8 15:33:58.894: CHAT3: Chat script INTERNET finished, status = Connection timed out; remote host not responding
debug cellular 0 messages all
Oct  8 15:31:27.762: [Cellular0]:MGMT RX (HEARTBEAT) (14 bytes):
00 0A 6B 1A 00 00 07 00 00 00 00 00 00 00
Oct  8 15:31:34.766: [Cellular0]:MGMT RX (HEARTBEAT) (14 bytes):
00 0A 6B 1B 00 00 07 00 00 00 00 00 00 00
Oct  8 15:31:41.766: [Cellular0]:MGMT RX (HEARTBEAT) (14 bytes):
00 0A 6B 1C 00 00 07 00 00 00 00 00 00 00
Oct  8 15:31:42.902: [Cellular0]:MGMT RX (MANAGE_PACKET_SESSION) (40 bytes):
00 24 6B 1D 70 04 07 00 00 00 00 00 00 1A 01 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 70 00
Oct  8 15:31:42.906: [Cellular0]:MGMT TX (PROFILE_SUMMARY Non-block) (14 bytes):
00 0A 2B 00 70 01 01 00 00 00 00 00 00 00
Oct  8 15:31:42.906: [Cellular0]:MGMT RX (AVAILABLE_SERVICE) (259 bytes):
00 FF 6B 1E 10 06 07 00 00 00 00 00 00 F5 00 01
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00
Oct  8 15:31:42.910: [Cellular0]:MGMT RX (SYSTEM_STATUS) (72 bytes):
00 44 6B 1F 70 0A 07 00 00 00 00 00 00 3A 00 03
00 02 00 02 00 00 00 00 00 00 00 00 03 00 47 00
42 00 52 04 00 33 00 20 00 55 00 4B 00 00 00 00
00 00 00 00 00 EA 00 14 00 33 00 FF 00 00 00 00
Oct  8 15:31:42.910: [Cellular0]:CALLCTRL RX Link Status Indication (218 bytes):
00 DA 78 00 01 01 00 D6 00 08 00 33 00 20 00 55
00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 4C 49 4E 4B 20 44 4F 57 4E 00 00 00 00
00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00
00 54 60 16 80 04 00 00 00 00 00 00 00 00 00 00
Oct  8 15:31:42.914: Incoming LSI msg: profile_id = 1, session_state = 0, pdp_context_no = 0
Oct  8 15:31:42.914: new DSR value received, 1
Oct  8 15:31:42.914: old value: handshakes->DSR= 1
Oct  8 15:31:42.914: ip address for profile id 1
87DC6FD0:                              000000
87DC6FE0: 0000
Oct  8 15:31:42.914: [Cellular0]:MGMT RX (PROFILE_SUMMARY) (33 bytes):
00 1D 6B 20 70 01 02 00 00 00 00 00 00 13 10 02
03 00 02 00 02 02 02 02 02 02 02 02 02 02 02 02
02
Oct  8 15:31:48.770: [Cellular0]:MGMT RX (HEARTBEAT) (14 bytes):
00 0A 6B 21 00 00 07 00 00 00 00 00 00 00
Oct  8 15:31:55.774: [Cellular0]:MGMT RX (HEARTBEAT) (14 bytes):
00 0A 6B 22 00 00 07 00 00 00 00 00 00 00
But I'm still none the wiser!  So, any further assistance would also be appreciated!
It is not okay to see
My output
#show cellular 0 network
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA (Attached)
Packet Session Status = Active
Country = CHN, Network = UNICOM
Mobile Country Code (MCC) = 460
Mobile Network Code (MNC) = 1
Gang Ma
Beginner
Under interface Cellular0
configure
ip address negotiation
DO NOT use "no ip address"
otherwise, the ip address can't install
Oct 21 05:21:19 UTC: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
Oct 21 05:22:41 UTC: %CELLWAN-2-CALL_SETUP_FAIL: Cellular0 data call setup failed due to mismatching IP address.
Oct 21 05:22:43 UTC: Cellular0 DirectIP: Configured IP address 0.0.0.0
does not match the IP address assigned by network 10.9.1.6. Disconnect the call!
Q. Can I configure a static IP address under my cellular interface or does the IP address always have to be negotiated?
A. It is highly recommended that the IP address always be configured as ip  address negotiated, even when a fixed (persistent) IP address is  required. The cellular interface is spoofed as up/up (status/protocol  states), regardless of whether or not the PPP is established. If this  interface is configured with a specific IP address (instead of ip  address negotiated), and if the PPP is not yet established, the routing  table interprets a valid route available through the cellular interface.  This problem is avoided by assigning a negotiated IP address. The  configuration given previously is particularly important when using the  cellular interface as a backup interface.
I think it will fix your issue!
Thanks for the suggestion - but I tried setting the IP address to negotiated and still no connectivity I'm afraid.
The dialer1 interface need encapsulation SLIP too
so
interface cellular0
ip address nego
interface Dialer1
encapsulation slip
username and password are not needed under dialer1 I think , because they are included in APN profile.
if the dial fails still,
please enable debug options and post the debug output
debug dialer
debug chat
debug modem
debug cellular 0 messages async
debug cellular 0 messages callcontrol
I have a C881G+7-K9 and configure it in two difference ways: with Dialer and without Dialer , both works!
and refer to
new 3G model uses a different 3G module, need different configuration.
I already had SLIP configured under the Dialer1 interface (from Daniel's suggestion above)
I turned on the debug you suggested, here is the output:
Oct 23 14:15:44.087: Di1 DDR: No free dialer - starting fast idle timer
Oct 23 14:15:45.087: Di1 DDR: No free dialer - starting fast idle timer
Oct 23 14:15:46.087: Di1 DDR: No free dialer - starting fast idle timer
Oct 23 14:15:46.335: CHAT3: Timeout expecting: OK
Oct 23 14:15:46.335: CHAT3: Chat script INTERNET finished, status = Connection timed out; remote host not responding
Oct 23 14:15:46.335: TTY3: Line reset by "Async dialer"
Oct 23 14:15:46.335: TTY3: Modem: (unknown)->HANGUP
Oct 23 14:15:46.335: TTY3: no timer type 0 to destroy
Oct 23 14:15:46.335: TTY3: no timer type 1 to destroy
Oct 23 14:15:46.335: TTY3: no timer type 3 to destroy
Oct 23 14:15:46.335: TTY3: no timer type 4 to destroy
Oct 23 14:15:46.335: TTY3: no timer type 10 to destroy
Oct 23 14:15:46.335: TTY3: no timer type 2 to destroy
Oct 23 14:15:46.987: TTY3: dropping DTR, hanging up
Oct 23 14:15:46.987: tty3: Modem: HANGUP->IDLE
Oct 23 14:15:47.087: Ce0 DDR: rotor dialout [best] least recent failure is also most recent failure
Oct 23 14:15:47.087: Ce0 DDR: rotor dialout [best] trying untried dialout
Oct 23 14:15:47.087: Ce0 DDR: rotor dialout [best] also has most recent failure
Oct 23 14:15:47.087: Di1 DDR: Nailing up the Dialer profile [attempt 54]
Oct 23 14:15:47.087: Di1 DDR: Dialer dialing - persistent dialer profile
Oct 23 14:15:47.087: Ce0 DDR: Dialing cause Persistent Dialer Profile
Oct 23 14:15:47.087: Ce0 DDR: Attempting to dial INTERNET
Oct 23 14:15:47.087: CHAT3: Attempting async line dialer script
Oct 23 14:15:47.087: CHAT3: Dialing using Modem script: INTERNET & System script: none
Oct 23 14:15:47.087: CHAT3: process started
Oct 23 14:15:47.087: CHAT3: Asserting DTR
Oct 23 14:15:47.087: CHAT3: Chat script INTERNET started
Oct 23 14:15:47.087: CHAT3: Sending string: AT!SCACT=1,1
Oct 23 14:15:47.087: CHAT3: Expecting string: OK
Oct 23 14:16:47.087: CHAT3: Timeout expecting: OK
Oct 23 14:16:47.087: CHAT3: Chat script INTERNET finished, status = Connection timed out; remote host not responding
Oct 23 14:16:47.087: TTY3: Line reset by "Async dialer"
Oct 23 14:16:47.087: Ce0 DDR: disconnecting call
Oct 23 14:16:47.087: TTY3: Modem: (unknown)->HANGUP
Oct 23 14:16:47.087: TTY3: no timer type 0 to destroy
Oct 23 14:16:47.087: TTY3: no timer type 1 to destroy
Oct 23 14:16:47.087: TTY3: no timer type 3 to destroy
Oct 23 14:16:47.087: TTY3: no timer type 4 to destroy
Oct 23 14:16:47.087: TTY3: no timer type 10 to destroy
Oct 23 14:16:47.087: TTY3: no timer type 2 to destroy
Oct 23 14:16:47.987: TTY3: dropping DTR, hanging up
Oct 23 14:16:47.987: tty3: Modem: HANGUP->IDLE
Oct 23 14:16:52.987: TTY3: restoring DTR
Oct 23 14:16:53.987: TTY3: CTS came up on IDLE line
Oct 23 14:17:02.087: Ce0 DDR: re-enable timeout
Oct 23 14:17:02.415: [Cellular0]:CALLCTRL RX Link Status Indication (218 bytes):
00 DA 78 00 01 01 00 D6 00 00 00 00 00 00 00 00
00 00 ED 00 ED 04 00 00 00 00 00 00 00 00 00 00
Oct 23 14:17:02.419: Incoming LSI msg: profile_id = 1, session_state = 0, pdp_context_no = 0
Oct 23 14:17:02.419: ip address for profile id 1
87BE7B30:                              000000
87BE7B40: 0000
Oct 23 14:17:02.423: Cellular0 DirectIP: Remove negotiated IP interface address
Oct 23 14:17:03.087: Ce0 DDR: rotor dialout [best] least recent failure is also most recent failure
Oct 23 14:17:03.087: Ce0 DDR: rotor dialout [best] also has most recent failure
Oct 23 14:17:03.087: Di1 DDR: Nailing up the Dialer profile [attempt 55]
Oct 23 14:17:03.087: Di1 DDR: Dialer dialing - persistent dialer profile
Oct 23 14:17:03.087: Ce0 DDR: Dialing cause Persistent Dialer Profile
Oct 23 14:17:03.087: Ce0 DDR: Attempting to dial INTERNET
Oct 23 14:17:03.087: CHAT3: Attempting async line dialer script
Oct 23 14:17:03.087: CHAT3: Dialing using Modem script: INTERNET & System script: none
Oct 23 14:17:03.087: CHAT3: process started
Oct 23 14:17:03.087: CHAT3: Asserting DTR
Oct 23 14:17:03.087: CHAT3: Chat script INTERNET started
Oct 23 14:17:03.087: CHAT3: Sending string: AT!SCACT=1,1
Oct 23 14:17:03.087: CHAT3: Expecting string: OK
hey
the AT dial command doesn't work. Modem doesn't accept the AT command AT!SCACT or it accept the AT string but dial fails
please try some different chat-script like
chat-script gsm "" "ATDT*99*1,1#" TIMEOUT 30 "CONNECT
chat-script gsm "" "ATDT*98*1,1#" TIMEOUT 30 "CONNECT
and you can reverse telnet to the line 3 and send AT command directly to the modem, check the bottom of the reference list you can find Sierra Wireless guide.
What is the exact model of the built-in modem?
C881G+7-K9 uses
#show controllers cellular 0
Interface Cellular0
3G Modem-QuadBand HSPA+R7/HSPA/UMTS QuadBand EDGE/GPRS Global and GPS,
Cellular modem configuration:
GSM-Carrier Type  : Cellular GSM Global.
Following is reference list
Cisco Configuration Guide
3G Mobile Broadband for the Branch office
http://www.cisco.com/web/TR/learn_events/expo2008/sunumlar/lars_thoren.pdf
Configuring 3G Wireless WAN on Modular and Fixed ISRs (HWIC-3G-GSM, HWIC-3G-HSPA, PCEX-3G-HSPA-x)
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlsgsm.html
Configuring Cisco EHWIC and 880G for 3.7G (HSPA+)/3.5G (HSPA)
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html#wp1513906
Configuring Cisco 4G-LTE Wireless WAN EHWIC
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/EHWIC-4G-LTESW.pdf
Cisco 3G Wireless WAN Enhanced High-Speed WAN Interface Cards for Cisco Integrated Services Routers Generation 2 Q&A
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7272/prod_qas0900aecd80600f5d.html
Dial-on-Demand Routing (DDR)
Configuring Dial-on-Demand Routing (DDR)
http://www.iphelp.ru/doc/3/Cisco.Press.CCIE.Practical.Studies.Volume.I/1587200023/ch07lev1sec3.html
Understanding and Troubleshooting Idle Timeouts
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a0080094eb7.shtml
Dialer Persistent
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t4/feature/guide/ftdperst.html#wp1030521
Dial Backup Using Dialer Watch Commands
http://www.cisco.com/en/US/docs/ios/12_0/dial/command/reference/drdbakdw.html
how-to-setup-dialer-persistent-for-cisco-3g-radio.html
http://www.jaydien.com/blog/cisco-products/how-to-setup-dialer-persistent-for-cisco-3g-radio.html
Configuration Demo & HOWTO
Understanding and Configuring a HWIC-3G-GSM
http://routing-bits.com/2010/05/12/hwic-3g-gsm/
Cisco 887 3G Router
http://www.problutions.com/?p=639
Initial configuration of a 881G router Cellular interface
http://inetpro.org/wiki/Initial_configuration_of_a_881G_router_Cellular_interface#Activate_Modem
Cisco 881G and PCEX-3G-HSPA Configuration Cheat Sheet
http://www.davidsudjiman.info/2009/05/29/cisco-881g-and-pcex-3g-hspa-configuration-cheat-sheet/
Cisco HWIC-3G How To
http://extwiki.snnap.net/twiki/bin/view/TechWeb/CiscoHwic3GHowTo
Cisco HWIC-3G-GSM Config
http://www.computecnetworks.com/?q=node/51
Supported_AT_Command_Reference-v2.4.pdf
http://www.sierrawireless.com/resources/documents/support/2130617_Supported_AT_Command_Reference-v2.4.pdf
C886VAG+7-K9
Secure Router with VDSL2/ADSL2+ over ISDN and Embedded 3.7G HSPA+ Release 7 with SMS/GPS
hmm HSPA+7
same as C881G+7-K9
the chat-script should be good for HSPA+7 modem
I get the following from sh controller cell 0  (which looks to be the exact same as your output from the C881G+7-K9)
Interface Cellular0
I will try some other chat scripts and see if it works (I have tried some already without any success - however, I think the one I have currently is the one that is actually specified in the guide for this router?)
yeah , the chat-script is good
My output
