Establishing a vpn connection between Azure and Cisco RV082
Hello
I'm working with a client that has Cisco RV082 firewalls and I'm attempting to get them connected to Windows Azure.
The Azure virtual gateway is a High Performance gateway that requires route-based vpns.
Does anyone know if this model firewall can do route based vpn tunnels?
Dave Liebau
carlguer
Hi Dave,
You should be able to establish the tunnel with the Azure with no problem.
Here you can find the link for the router features:
http://www.cisco.com/c/en/us/products/collateral/routers/rv082-dual-wan-vpn-router/data_sheet_c78-501227.html
- Javier -
