03-20-2023 11:11 PM
How do I create multiple BGP neighbor peering from multiple tunnel IPs to one destination IP and remote-as?
and when it comes to setting the routing preference how do we do that
if someone can share a sample config.
Diagram
03-21-2023 12:59 AM - edited 03-21-2023 01:01 AM
Hello @chin_DC
Example:
interface Tunnel1
ip address 10.1.1.1 255.255.255.0
tunnel source Loopback0
tunnel destination 192.0.2.1
interface Tunnel2
ip address 10.1.2.1 255.255.255.0
router bgp 65000
neighbor 192.0.2.1 remote-as 65001
neighbor 10.1.1.2 remote-as 65001
neighbor 10.1.2.2 remote-as 65001
address-family ipv4
neighbor 192.0.2.1 activate
neighbor 10.1.1.2 activate
neighbor 10.1.2.2 activate
neighbor 10.1.2.2 route-map set-local-pref in
route-map set-local-pref permit 10
match ip address prefix-list TUNNEL2-PEER
set local-preference 200
ip prefix-list TUNNEL2-PEER seq 10 permit 10.1.2.2/32
The reason for specifying the remote IP addresses of Tunnel1 and Tunnel2 in addition to the BGP peer's IP address is to ensure that the BGP updates are sent and received over the correct tunnel interface. By explicitly defining the remote IP addresses of the tunnel interfaces, the router ensures that BGP traffic is sent through the correct tunnel and that the BGP neighborship is established over the correct interface.
With this configuration, the local preference is set to 200 for BGP updates received over Tunnel2. This can influence the routing decisions for incoming traffic from that BGP peer, making it more preferred over other BGP peers.
03-21-2023 06:28 AM
Thanks for the detailed explanation.
The local preference is set to 200 and this is for incoming traffic, my requirement is for outbound, the remote end is a cloud provider, and the default route is pointing to the cloud.
How do I achieve this ?
03-21-2023 06:45 AM
keep away load sharing now,
you have four tunnel end to same destination, GRE accept that
but
BGP allow you to establish only one TCP session between two Peer (because the distention is same)
so either union the tunnel or union the BGP
there is no other solution
03-21-2023 06:57 AM
The LP 200 is applied to the prefixes received from neighbor 10.1.2.2 , then yes it's in INBOUND (in).
The LP 100 (default) is applied to the prefix received from neighbor 10.1.1.2
Then, on the routing table on the edge router, the flow will choose TUNNEL-2 in primary due to the LP 200 to go OUTSIDE.
If you want to force traffic from outside to inside to come from TUNNEL-2, then you can use AS-PREPEND [AS-PATH], community or MED, depend of the remote end.
03-21-2023 01:24 AM
Hello
You should only require a single bgp peering as an overlay to an igp such as ospf, This will provide resiliency plus you could then cost out the tunnels to the most preferred.
The single bgp peering would be a loopback (most preffered)
example:
int loopback 0
ip address 1.1.1.1 255.255.255.255
ip ospf x area 0
int tun 1
ip ospf x area 0
int tun 2
ip ospf x area 0
ip ospf cost 10
int tun 3
ip ospf x area 0
ip ospf cost 15
int tun 4
ip ospf x area 0
ip ospf cost 20
router ospf 1
router-id 1.1.1.1
router bgp1
bgp log-neighbor-changes
neighbor 1.1.1.2 remote-as 2
neighbor 1.1.1.2 ebgp-multihop 2
neighbor 1.1.1.2 update-source Loopback0
03-21-2023 02:55 AM
you can do
config LO in both side and use LO as tunnel source and tunnel destination, this will give you the load sharing for tunnel
or you can do
run multi tunnel and then use LO in BGP.
it up to you.
