Etherchannel is ISR2900
snarayanaraju
Level 4
Level 4
Hello Friends,
I have configured Etherchannel in Cisco 2951 ISR router using Integrated port G0/1 and 0/0. It is working perfectly. The question is why i am not seeing any output about the etherchannel details when i issue show command. IOS Version: 15.0
Router #show etherchannel summary
Flags:  D - down             P - in port-channel
        I - stand-alone      s - suspended
        R - Layer3           S - Layer2
        U - in use
Group Port-channel  Ports
Router#
interface GigabitEthernet0/0
description ** LAN**
no ip address
ip flow ingress
load-interval 30
duplex auto
speed auto
channel-group 1
no mop enabled
service-policy output voice-protect
end
Thanks in advance
SAIRAM
Lei Tian
This looks similar to CSCtx30338. You are not using L3, but this bug may apply. What you have on the other end, does it show the etherchannel correctly?
Symptom:
Etherchannel output for L3 ports not displaying correctly.
Conditions:
The CLI's given are incomplete and not working properly.
"show etherchannel"
"show interface port-channel etherchannel"
"show interface f0/0 etherchannel"
Workaround:
Can use alternate working CLI to get etherchannel details
"show interface port-channel "
HTH,
Lei Tian
Lei Tian
Symptom:
Conditions:
"show etherchannel"
Workaround:
HTH,
Lei Tian
