Evaluation License File install Fail!
davidbranka
I'm trying to install a license file on a 3750x stack of 4 switches.  I was running IPBase but want to upgrade to IPServices.
Install a License
     3750E#copy tftp flash1:
     3750E#172.x.x.x
     3750E#FDO1111111_201101111111111.lic
3750E# license install flash1: FDO1111111_201101111111111.lic
Installing licenses from "FDO1111111_201101111111111.lic"
       Installing...Feature:ipservices... Successful:Supported
     1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses were failed to install
I did not get this message below after the install of the license.
19:46:56: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Next reboot level = ipservices and License = ipservices
After I installed the license file on all four switches I rebooted my stack and it did not start using ipservices, still running IPBase.  I tried to raise the priority of ipservices by using  "license modify priority  ipservices high" and lower ipbase using "license modify priority ipbase low" but I get errors when I try this.
% Error: License priority modification failed: Invalid operation
        Feature: ipbase   Version: 1.0
% Error: License priority modification failed: Selected license line's precedence is in incorrect state
davidbranka
Answer to my problem.  Would be nice if this was added to the Q&A page for license install.
https://supportforums.cisco.com/thread/2055932
3)Optional (in case you have multiple licenses installed or havent cleared the previous license)
license boot level license-level [switch switch-num]
