exclude a network from PBR
manvik
Level 3
Level 3
in my catalyst have a PBR (policy based routing) which redirects all TCP 443 destination traffic to a different server/IP.
how can I exclude one destination IP or network from this PBR.
current config;
ip access-list extended 110
102 permit tcp any any eq 443
103 permit tcp any any eq www
104 permit icmp any any
route-map pbr-web permit 10
match ip address 110
set ip next-hop 172.20.x.x
Jon Marshall
It depends on your switch but they don't always support route map deny statements and in addition they recommend not to use deny lines in your acl because that sends the packets to the CPU which has a hit on performance.
You could try having a permit statement before your existing one ie.
route map pbr-web permit 5
match ip address <acl no>  <--- this matches the IP or IPs you want to exclude
with no set statement it should just use the global routing table but you would need to test.
Of course your switch may not have the above limitations, you need to check the configuration guide to be sure.
Jon
15 Replies 15
Add route-map seq 5 deny
Match acl "Permit host ip tcp port"
Then use same previous route-map 10 permit
Jon Marshall
Jon
manvik
Level 3
Level 3
Thank you @Jon Marshall @MHM Cisco World i tried below, still no luck. any changes to be done?
ip access-list extended 111
101 permit ip any 172.24.0.0 0.0.31.255
route-map pbr-web permit 5
 match ip address 111
 set ip next-hop 10.20.60.2
set ip next-hop 10.20.5.1
Your PBR looks fine so the interface you have applied it to, is that where all the traffic arrives at the device on ?
Jon
Yes, it's applied to a VLAN interface. acl 110 is working fine. traffic is going to IP in the route-map 10
So the exclusion is for any traffic going 172.24.0.0 -> 172.24.31.255 ?
There is nothing wrong with your PBR configuration assuming the above and the next hop IP is reachable from the switch but difficult to say for sure without knowing your network topology.
Jon
Just push route map line 10 to be 5
And route map line 5 to be 10
That it
Hello
Create a new acl for that specific or any future hosts you wish to deny from the policy then also create an additional PBR deny stanza then just add that newly created ACL only and nothing more
Example:
permit ip host x.x.x.x any
route-map pbr-web deny 5
Kind Regards
Paul
manvik
Level 3
Level 3
thank you @paul driver @Jon Marshall
tried with this too;
101 permit ip host 0.0.0.0 172.24.0.0 0.0.31.255 log
We are testing access to an website in 172.24.x.x, from a client system. Site is not loading. Traceroute shows hope till this switch only.
Is the next hop of 10.20.60.2 directly connected to the switch ?
Jon
yes it is.
manvik
Level 3
Level 3
Guys i got it working, thank you for the support. Working commands;
As i mention above
You push acl for tcp up
Good job friend.
Hello
Glad you got it working however the example I provided should have also worked without specifying any other next hop ip address -UNLESS that is  you wanted to PBR that specific host to yet another next-hop address other than the default set in the GRT.
Kind Regards
Paul
