Extended ping question
SPYME.GOOGLE
I have the following questions
1. What does "Validate reply data?" means in an extended ping. So what exactly it validates in the reply data.?
2. What happens if i set the datagram size to be 4000 bytes and set the sweep range from 36 to 18024 bytes. Does this overwrites the maximun datagram size i orginally mentioned.
3. Finially my problem when Im doing an extended ping with the settings in point 2 Im receiving only 99% ping success ful over my new telco network. So how od i know which packet it is dropping. Iam seeinga dot message in with the !.
Richard Burts
The ping packet has a payload (the size of the payload depends on what you specify for the packet size) and one of the extended commands gives you the ability to specify what the payload will be - by default it is hex values of ABCD. If you select validate reply data it will check the response packet to verify that the payload received is an exact match for the payload sent out.
If you specify the datagram size to be 4000 and then you sweep it will generate data up to the size that you specify in the sweep. And when the datagram gets to the interface it will be fragmented into packets that will fit the frame size of the interface.
Without doing more investigation (packet capture, or packet debug, etc) I do not know how you would determine exactly which packets are being dropped.
Rick
Rick
