External data Keywork on ROute
Rupesh Kashyap
Hi, What is the meaning of External Data ?
R>sh ip ei topology 10.4.6.0 255.255.255.0
IP-EIGRP (AS 1): Topology entry for 10.4.6.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 373760
Routing Descriptor Blocks:
10.3.1.2 (Multilink10), from 10.3.1.2, Send flag is 0x0
Composite metric is (373760/153600), Route is External
Vector metric:
Minimum bandwidth is 7936 Kbit
Total delay is 2000 microseconds
Reliability is 243/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
External data:
Originating router is 10.3.1.2
AS number of route is 65040
External protocol is BGP, external metric is 0
Administrator tag is 65140 (0x0000FE74)
Giuseppe Larosa
Hello Rupesh,
EIGRP external routes data structures contain additional fields:
the EIGRP router-id of the router that injected the route in the EIGRP domain.
10.3.1.2.
The protocol from which the route has been learned is BGP with BGP as number 65040.
the route tag is a copy of BGP AS number (this is a default).
The BGP metric MED is 0.
This information is carried to provide a way to rebuild (at least partially the AS path cannot be rebuilt) the original BGP route in another node.
Hope to help
Giuseppe
