Facing problem to configure Cisco 877w
ajayprabhakar
I want to configure 877w for my DSL connection. The service provider has provided me with a Zyxel 660R61 router for which configuration are :
Mode: Routing
Encapsulation: ENET ENCAP
MUX : LLC
PVC : 1/32
Static IP: As provided
Subnet Mask: As provided
GW IP: As provided
Note: The static ip is provided by the ISP
For 877w configuration,
I have configured interface atm0.1 with the given static ip and encapsulation as aal5snap plus added ip routing for the given Gateway.
Hereafter I am unable to ping the gateway. Debugging the IP packets shows only outgoing packets and no error is displayed. Please help me out.
PS: If someone else has configured Cisco 877w with static IP for Airtel(India), please guide me asap.
paolo bevilacqua
possibly they are using "bridged" encapsulation and not routed. Please configure:
int atm0.1
no ip address
no ip nat outside
bridge-group 2
int bvi2
ip address
ip nat outside
bridge irb
bridge 2 route ip
Note: the reason of using 2 for BVI is that you should already have BVI1 for WLAN / LAN.
If still doesn't work, please send configuration after the changes indicated above.
I tried configuring 877 for bridge+route mode as per the guide on cisco.com. Also I applied your suggested config however, there is no luck. My config are :-
bridge irb
interface ATM0
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
dsl operating-mode itu-dmt
interface ATM0.1 point-to-point
no snmp trap link-status
atm route-bridged ip
pvc 1/32
encapsulation aal5snap
bridge-group 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface BVI1
mac-address 001a.e321.abca
ip address dhcp client-id FastEthernet0
interface BVI2
ip address W.X.Y.Z 255.255.255.0
ip route 0.0.0.0 0.0.0.0 ATM0.1 w.x.y.z
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 route ip
Please suggest
please configure:
no atm route-bridged ip
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
no ip tcp adjust-mss 1452
interface BVI1
no mac-address 001a.e321.abca
ip nat inside
interface BVI2
ip nat outside
no ip route 0.0.0.0 0.0.0.0 ATM0.1 w.x.y.z
ip route 0.0.0.0 0.0.0.0 w.x.y.z
ip nat inside source list 7 interface bvi2 overload
If stil doesn't work, send revised config and output of "show atm pvc 1/32"
hi ajay,
i am also trying the same you got the solution ..if u got the solution can you plz send the config to me
i am also having airtel connection with static ip connection (airtel provided the beetel modem)
thanks
cyril
