Failed to change PRL region
khairul_alam
I'm trying to change the cellular PRL Region on a C897VAG-LTE-GA-K9 to 3. But it's showing "Failed to change PRL region".
Router#cellular 0 lte prl-region 3
!!!WARNING: PRL region view/set requires modem reset, call will be disconnected!!!
Are you sure you want to proceed?[confirm]
Current PRL is 0, will be changed to 3
Resetting modem, please wait...
Can any one help me regarding this?
Khairul
cliveferguson
How was this resolved in the end for you?
I have similar;
Try to select PRL region as Europe fail:
lonoff04-oob-vpn01#cel 0 lte prl-region 1
Current PRL is 0, will be changed to 1
Khairul
