Failover question
wasahongNYC
I’d like to ask some failover question. Please help me with it.
Thanks in advance.
In my network, the network is working well. It can ping 4.2.2.2. In order to test failover,
I shut down the interface Gi 1/12 of Core1 switch. After this,
From Host, it can ping the router 1 outside interface IP, X.X.X.X
And router 1 outside interface can ping 4.2.2.2
But the host is NOT able to ping 4.2.2.2.
And I found that the ASA outside interface can ping 4.2.2.2, but ping 4.2.2.2 with ASA inside interface does NOT work.
I have no idea how to troubleshoot it.
So please help me
Thank you very very much
router config :
no aaa new-model
ip cef
ip domain round-robin
ip domain name aaaaa
ip name-server 4.2.2.2
archive
log config
hidekeys
interface Loopback100
description mgmt interface
ip address 10.0.100.13 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0
description ISP circuit order 1-111111111111
ip address X.X.X.X 255.255.255.248
ip accounting output-packets
ip nat outside
ip nat enable
no ip virtual-reassembly
duplex full
speed 1000
media-type sfp
no negotiation auto
interface GigabitEthernet0/1
description uplink to main-1 interface g 1/0/12
ip address 192.168.2.253 255.255.255.0
ip nat inside
ip nat enable
duplex full
speed 1000
media-type sfp
no negotiation auto
standby 2 ip 192.168.2.254
standby 2 priority 110
standby 2 preempt
interface GigabitEthernet0/2
ip address 192.168.3.253 255.255.255.0
no ip redirects
duplex full
speed 1000
negotiation auto
standby 3 ip 192.168.3.254
standby 3 priority 110
standby 3 preempt
interface GigabitEthernet0/3
no ip address
duplex full
speed 1000
no negotiation auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 10.1.0.0 255.255.0.0 192.168.2.1
ip route 10.1.20.0 255.255.255.0 192.168.2.13
no ip http server
ip dns server view-group aaaaaaa
ip dns server
ip nat pool mypool X.X.X.X X.X.X.X netmask 255.255.255.252
ip nat inside source list 1 pool mypool overload
logging alarm informational
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
control-plane
gatekeeper
shutdown
switch config :
ip domain-name xxxxxxxxxxxxxxxxxxxxxxxxx
ip address 10.0.100.15 255.255.255.255
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description uplink to asa12 port 0/0
interface GigabitEthernet1/0/6
description uplink to router02 port g 0/1
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description uplink to asa11 port 0/0
interface GigabitEthernet1/0/12
description uplink to router01 port g 0/1
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.4 255.255.255.0
ip default-gateway 192.168.2.254
ip http server
ip http secure-server
monitor session 1 source interface Gi1/0/12
monitor session 1 destination interface Gi1/0/2
end
ASA config:
description STATE Failover Interface
interface Management0/0
description LAN Failover Interface
management-only
media-type sfp
nameif outside
security-level 0
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet1/1
media-type sfp
nameif inside
security-level 100
ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet1/2
media-type sfp
nameif inside-backup
security-level 100
ip address 192.168.5.1 255.255.255.0
interface GigabitEthernet1/3
media-type sfp
nameif outside-backup
security-level 0
ip address 192.168.3.1 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group icmp-type AllowedICMP
icmp-object echo
icmp-object echo-reply
icmp-object traceroute
icmp-object unreachable
icmp-object time-exceeded
access-list EXEMPT extended permit ip 192.168.4.0 255.255.255.0 any
access-list EXEMPT extended permit ip 10.1.0.0 255.255.0.0 any
access-list EXEMPT extended permit ip 192.168.5.0 255.255.255.0 any
access-list no-nat extended permit ip 10.1.0.0 255.255.0.0 host 0.0.0.0
access-list outside_access_in extended permit icmp any any object-group AllowedICMP
access-list outside_access_in extended permit ip host 192.168.2.253 any
access-list outside_access_in extended permit ip 192.168.2.0 255.255.255.0 any
failover
failover lan unit secondary
failover lan interface fobasic Management0/0
failover key *****
failover link fostate GigabitEthernet0/3
failover interface ip fobasic 192.168.200.1 255.255.255.0 standby 192.168.200.2
failover interface ip fostate 192.168.201.1 255.255.255.0 standby 192.168.201.2
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo-reply outside
icmp permit any unreachable outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (outside-backup) 1 interface
nat (inside) 0 access-list no-nat
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group outside_access_in out interface outside
access-group EXEMPT in interface inside
access-group EXEMPT out interface inside
router eigrp 10
no auto-summary
network 192.168.2.0 255.255.255.0
network 192.168.3.0 255.255.255.0
network 192.168.4.0 255.255.255.0
network 192.168.5.0 255.255.255.0
redistribute static
route outside 0.0.0.0 0.0.0.0 192.168.2.254 1
http 10.1.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
track 1 rtr 123 reachability
management-access inside
dhcpd dns x.x.x.x
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
service-policy global_policy global
2 Accepted Solutions
Abzal
Level 7
Level 7
Hi Sam,
You need to add subnets to NAT ACL on the router where hosts are located. I guess they are:
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
And other subnets if you have them. Then remove on the router's interface:
int g0/0
no nat enable
int g0/1
no nat enable
Then try to test again failover it should work.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
On the left ASA you're doing NAT so inside LAN subnet 192.168.4.0/24 gets translated into 192.168.2.1. I believe that's why you didn't need to add subnet into ACL. About ASA on the right side I cannot tell for sure. I think there might be NAT haven't been configured. So subnet are not getting translated instead just being forwarded to the router. For sure I can tell only after I see the config. of ASA and switches that is connected to.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
10 Replies 10
Abzal
Level 7
Level 7
Hi Sam,
int g0/0
no nat enable
int g0/1
no nat enable
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
hi Abzal,
Thank you so much for your reply.
and,
I've got another NAT exempt question.
when I debug NAT on the router,
the NAT transformation is like
s=192.168.2.1 -> X.X.X.X d=4.2.2.2
but my host inside the Firewall is, let's say 10.1.33.40.
so I think the NAT should be,
s=10.1.33.40 -> X.X.X.X d=4.2.2.2 since the IP doesn't transform by the firewall.
so what is wrong with my concept ?
Thanks again,
Nothing is wrong in you concept. Because you are using NAT it means that IP of source host inside your private LAN will be changed when packet goes outisde of your private to access public Internet. Because private addresses are non routable on the Internet. So NAT changes IP address of source with external IP address.
And on routers you need to show in ACL which IP addresses or subnets are allowed to go outside. When packets come to the router and packet is destined to the Internet, first it compares source IP address against NAT ACL then if it finds a match router does a paclet translation and packet goes out from outisde interface.
Here are great links that'll help you
http://book.soundonair.ru/cisco/ch24lev1sec1.html
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094831.shtml
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
hi Abzal,
I've got another question.
in the first place, I didn't configure "access-list 1 permit 192.168.4.0 0.0.0.255"
It can ping very well.
But when the left firewall became standby and the right firewall became active,
then I need to confgire that command on router.
otherwise it was NOT able to failover.
so my question is that when the left firewall is Active, then I do NOT need to configure that command.
while when the right firewall is Active, then I DO need to configure that command.
Is there any link which can answer this question ?
Thanks again,
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
about firewalls, they are sync.
the Active(left side) one has the same configuration with the Standby(right) one.
That was why I ask you this question.
I think I need to research about firewalls more then ask.
Thanks again ~
BTW, when I shut down the Gi 1/12 interface of Core 1 switch,
then the left firewall became standby and right one became active.
but,
when I shut down the 1/1(or 1/0 )interface of left ASA, the left ASA keeps Active and the right ASA
keeps Standby.
This is also one point which I don't understand now.
Thanks again and I am going to reserach more.
hi Abzal,
sorry I've got another question.
Please help me when you get a chance ?
when I turn off the Gi 1/12 interface of Core 1 switch,
the firewall failover automatically.
but ...
when I turn off 1/0 or 1/1 interface of left firewall,
it did NOT failover automatically.
Do you know why ?
according to the cisco book "Cisco ASA 5500 series Configuration guide using the CLI"
Failover Behavior,
Failure Event                          Policy     Active Action             Standby Action          Notes
Interface failure on active unit   Failover   Mark active as failed   Become active
above threshold
In my case I shut down the 1/1 interface of left(Active) firewall, so it should go to Standby firewall.
but it remained Active.
This is my question.
Thanks a million,
thanks,
hi
I just found this article,
https://supportforums.cisco.com/thread/228489
I am going to test it first.
So you could ignore the previous question,
thanks,
hi Abzal,
I've followed this link,
but when I shut down the inside interface of left ASA,
it failed to failover.
Is it related to vlan 4 interface ?
Hi Abzal,
It is working now. It can failover well.
I truly truly appreciate your help.
Thanks a million
Best,
