fan
amansoi_5
Is there any command available on Cisco 1751 router to check whether fan is working or not ?
regds,
aman
5 Replies 5
stephtchoko
Level 3
Level 3
Good day,
try Show environement or show techsupport, and check the content.
jarathbu
Are you getting specific messages in the log? I don't think there is a specific CLI to check if the fan is operational or not on the 1700 platform.
James
show environment command is not working . In tech support output , there is nothing related to fan.
In log , there is no message related to fan
regds,
aman
Escume me,
show environment can help you to see and compare normal temperature and current temperature.
Reagards.
show environment command does not work on Cisco 1750 series.. ButI have tried with Cisco 1841 router , it is working...
aman
