Fast Ethernet Duplex Issues
laitonglek
Dear Expert,
I was using the Cisco 2811 router, behind it having 2 FE port, when I try to change the mode of the duplex, from half to full, after that we do show interface, it indicate the interface is administrative down. This situation is very weird. Does anyone face this kind of situation before?
7 Replies 7
spremkumar
Level 9
Level 9
Are you getting the interface down after making the duplex to full ?
did you see any error logs in your router regarding the same ?
regds
Dear spremkumar,
The status show the interface is administrative down, and the connection also lost as well.
sorry during that time forget to see the log.
Can you post the config of the router and also the output of show ip int brief as well as show version ?
regds
sh version as below:
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(8a), R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 19-Jul-06 23:21 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
xxx uptime is 3 days, 1 hour, 57 minutes
System returned to ROM by Reload Command
System restarted at 14:31:31 MY Fri Mar 30 2007
System image file is "flash:c2800nm-advsecurityk9-mz.124-8a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK0932F17M
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
sh ip inter brie as below:
xxx#sh ip inter brie
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.106.16.1 YES NVRAM up up
FastEthernet0/1 192.168.20.3 YES NVRAM up up
NVI0 unassigned NO unset up up
For the configuration, sorry i can;t provide to you due to some company policy.
Your interfaces is "up up". If it is as what you said "administratively down", it should show "administratively down down" or did you put it back to its original config or did you took the "show ip int brief" output from the wrong router?
Exactly if you type the command you should see both of the Fa/0 interfaces adminis up/up.
You could maually shut the interface down and bring back up int fa0/0 no shut
fa/01 no shut
Then try the sh ip int br and they should come up
dasadino2003
To resolve the problem on the fa0/0 and fa0/1 interfaces, you need to use the "no shutdown" command in the interface mode.
