10-31-2012 12:02 PM - edited 03-04-2019 06:01 PM
Hi ,
We have got ethernet link ie RJ45 MPLS link , but we have fast ethernet port (Fast-Ethernet PA, 1 ports, 100BaseFX-ISL ) on router .I need to have converter ie Fast-Ethernet PA, 1 ports, 100BaseFX-ISL to 10/100BaseTX Media converter so that i can connect ethernet link on the converter.
Please suggest what kind of converters are available in the market and which one is the best.
show diag is as below :
Slot 5:
Physical slot 5, ~physical slot 0xA, logical slot 5, CBus 0
Microcode Status 0x4
Master Enable, LED, WCS Loaded
Board is analyzed
Pending I/O Status: None
EEPROM format version 1
VIP4-50 RM5271 controller, HW rev 2.01, board revision A0
Serial number: 22618578 Part number: 73-4708-02
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 31 02 01 01 59 21 D2 49 12 64 02 00 00 00 00
0x30: 50 05 35 00 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x4 Insertion time: 0x28DC (5y4w ago)
Controller Memory Size: 128 MBytes CPU SDRAM, 64 MBytes Packet SDRAM
PA Bay 0 Information:
E3 Serial PA, 1 ports
HW rev 1.01, Board revision C0
Serial number: 33823684 Part number: 73-2620-03
PA Bay 1 Information:
Serial number: 12277906 Part number: 73-1690-04
sh version
IOS (tm) RSP Software (RSP-PV-M), Version 12.0(18)S5a, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sun 20-Jul-03 13:09 by dchih
Image text-base: 0x60010968, data-base: 0x60E72000
ROM: System Bootstrap, Version 12.0(10r)S1, RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-PV-M), Version 12.0(18)S5a, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router 1 uptime is 5 years, 4 weeks, 5 days, 11 hours, 14 minutes
System returned to ROM by processor memory parity error at PC 0x6072B2C0, address 0x0 at 03:27:18 gmt Sun Sep 30 2007
System restarted at 03:28:08 gmt Sun Sep 30 2007
System image file is "slot0:rsp-pv-mz.120-18.S5a.bin"
cisco RSP4+ (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
Chassis Interface.
1 EIP controller (6 Ethernet).
5 VIP4-50 RM5271 controllers (3 FastEthernet)(16 Serial)(1 POS).
6 Ethernet/IEEE 802.3 interface(s)
3 FastEthernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
1 Packet over SONET network interface(s)
123K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 7.
Configuration register is 0x102
Thanks ,
M S K
10-31-2012 12:04 PM
I prefer Transitions.
11-01-2012 07:38 AM
Hi Collin ,
Thanks for you prompt reply.
What kind of fiber cable i should use to connect fast ethernet interface ( Fast-Ethernet PA, 1 ports, 100BaseFX-ISL ) with media converter.
Is it SC or ST fiber cable.
Thanks ,
M S K
11-02-2012 03:09 AM
I think it would be easist if you called Transition and tell them what you have. They're the experts in that area and can determine the product a lot quicker than I can.
http://www.transition.com/TransitionNetworks/ContactUs/Contact.aspx
