Filter ::/0 EIGRP out interface
sebastien3
Level 4
Level 4
With EIGRP IPV6 I want to redistribute the static and connected routes but not the
default route ::/0
distribute-list prefix-list FILTER_EIGRP out GigabitEthernet1/0
redistribute static
redistribute connected
ipv6 prefix-list FILTER_EIGRP seq 10 deny ::/0
ipv6 prefix-list FILTER_EIGRP seq 20 permit ::/0 le 128
interface Loopback0
no ip address
ipv6 address 2001:db8:1:1:1:1:1:100/128
ipv6 enable
If I use the FILTER_EIGRP filter it works for the
default route ::/0
but not with an IPV6 of loopback0 which is in (LC) Local/Connected.
This filter rule work for a subnet IPV6 /64 Static (S).
How would you write the filtering
access list FILTER_EIGRP
18 Replies 18
Hi @sebastien3 ,
The issue is with the
eigrp stub
configuration. Please change the following:
eigrp stub redistributed
To:
eigrp stub redistributed connected
The
loopback ipv6
address will then be advertised.
Hi @Harold Ritter ,
You are right, the connected was missing !
I need an explanation on this. In IPV4 also in stub I don't need to use "connected" so that the IPs of the loopbacks are propagated. Can you tell me if this is an EIGRP IPV6 specificity ?
Hi @sebastien3 ,
 It definitely appears to be an
eigrpv6
implementation difference.
As can be seen below, the
lo0 ipv6
address is flagged as "Connected" in the topology database, while the
lo0 ipv4
Rconnected
(or redistribute connected). This is most likely why only
stub redistributed
is sufficient with IPv4 to advertise the
lo0
address, while
is required with IPv6.
DUT#sh ip eigrp topo
EIGRP-IPv4 VR(EIGRP) Topology Table for AS(10)/ID(192.168.100.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 192.168.100.1/32, 1 successors, FD is 163840
        via Rconnected (163840/0)
DUT#sh ipv6 eigrp topo
EIGRP-IPv6 VR(EIGRP) Topology Table for AS(10)/ID(10.10.10.229)
P 2001:DB8:1:1:1:1:1:100/128, 1 successors, FD is 163840
        via Connected, Loopback0
THANKS @Harold Ritter  ! I also agree with you, this explains why I had no problem with IPV4.
