Filter EIGRP updates?
Gregory Welch
        I have three routers connected to a private circuit and routing via EIGRP.  The routers are physically located in California, California, and Minnesota.  The problem is, when I do a show ip route, I get:
D EX    10.246.174.0/24
           [170/26456320] via 172.16.1.252, 08:18:48, GigabitEthernet1/0/1
           [170/26456320] via 172.16.1.250, 08:18:48, GigabitEthernet1/0/1
           [170/26456320] via 172.16.1.248, 08:18:48, GigabitEthernet1/0/1
Right now traffic is load balancing between the routers instead of using the closest router.  How do I filter EIGRP updates to prefer a particular route?
patrick.preuss
Hi Gregory
i asume that you have a full meshed network.
Normaly you will do this with the metric and not via a fillter because you might what to have backup.
If you what to fillter you might what to have a look a the distribute list.
https://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfeigrp.html#wp1030091
HTH Patrick
mahmoodmkl
Level 7
Level 7
i suggest u can use offset lists
